محدش علق علي الموضوع يعني
رقم العضوية : 37364
الاقامة : HARAM
السيارة: VW passat B7 - Verna 1.6
السيارة[2]: BMW 335i - volvo s80
دراجة بخارية: non
فادي عزت شوف يا باشا الموضوع ده كده
Early Air Conditioner compressors manufacturered by Zelex/Valeo and installed in the Golf, Passat, Jetta,Octavia a5 and Eos until June 2007 have a reasonably good chance of early failure due to a lubrication problem inside the compressor. This causes ....l fatigue and eventually the breakage of the compresser shaft which distributes ....l particles around the system. Volkswagen are covering replacements out of warranty, in Germany the parts are covered for five years and 150,000 km with Volkswagen covering 50% of the labour costs in the fourth year and none in the fifth year. In Australia cars have been covered 6 months out of warranty.
The fix requires a new compressor manufactured by Sanden part number 1K0 820 803 (1K0820803) and index S or greater 1K0 820 803 S (1K0820803S), the replacement of the expansion valve along with a new condenser. To clean out the ....l particles the system has to be flushed for 4+ hours.
The Zelex/Valeo compressor can be identified by the photo on the right, the part number will be 1K0 820 803 L (1K0820803L) or 1K0 820 803 N (1K0820803N). The failure can be identified in two ways;
- The limiter (indicated by 1 on the photo) is broken or is missing
- The compressor control valve is restricted by ....l particles and the compressor does not build up pressure.
The compressor replacement, expansion valve, condensor and labour cost around AUD$3000. A new compressor is around AUD$1200.
Details of the Sanden Compressor are here – Sanden PXE16 Air Conditioner Compressor Specifications (1K0820803)
Some information (in German) is available at Autobild.de
right now,after year 2007 for all VW group cars, the manufacture replaced the compressor and the issue is finally solved.
Models affected
Eos – 2007
Jetta – 2005 – 2007
Golf, Rabbit, GTI, Passat – 2006 – 2007
Skoda Octavia a5 - 2005 - 2007
SkodaTechnical Bulletin # 2013314
أظن الرد واضح جدا إن بعد موديلات 2007 مفيش أي مشاكل في التكييف.
رقم العضوية : 37364
الاقامة : HARAM
دراجة بخارية: non
رقم العضوية : 114405
الاقامة : alexandria
السيارة: SKODA A4
السيارة[2]: skoda A5
و الله برافو عليك انك راسلت الشركه .. و هما بيعترفوا بخطائهم ... طيب حا نتعوض ازاى ؟؟؟ المفروض لو شركه محترمه كانت سجبت كل عربياتها و غيرت الكباس على حسابها زى ما عملت قبل كده تويوتا ...
بس الغريب ان هما بيقولوا ركب تكييف ساندن !!!!؟ معنى كده انى الحمد لله ركبت الكباس الصح الى عند ساندن المعادى و كان صناعته امريكى ...
كان المفروض كلنا نرفع قضيه على الشركه و ناخد حقنا .. و ما خفى كان اعظم .. يمكن كمان مشكله الفتيس دى من عندهم كمان ... تحياتى لك
رقم العضوية : 37364
الاقامة : HARAM
دراجة بخارية: non
أنا بالفعل راسلت الشركة يا باشا وردو عليا رد عجيب جدا..إنهم كانوا بياخدوا ريبورت بصفة دورية من الإدارة الخاصة بيهم تحت إشراف مهندس شفيق جبر بإن مفيش أي شكوي مننا بخصوص التكييف.في الموديلات 2006-2007
موضوع الفتيس يا باشا هو مش عيب ولا مشكلة,ده بيرجع لطبيعة إستعمالك.هتحافظ عليه بإنك تواظب علي تغيير الزيت كل 60 ألففففف كيلو ولا هتسيبو يبوظ...بس كده.بسيطة يعني
السيارة: SKODA A4
تحت اشراف شفيق جبر ؟؟؟؟؟؟؟؟؟؟؟؟؟؟ ايه الفساد ده ... و هوا كان حا تفرق معاه ايه لو كان بلغ الشركه ان فيه عيب تصنيع ... رجل اعمال بالحجم ده و يطلع كداب و غشاش..... الفساد طال كل شىء فعلا
اما موضوع الفتيس فا عندك حق فى النقطه دى انا غيرت البودى فالف بسبب انى نسيت بصراحه اغير الزيت .. بس الموضوع زايد اوى فى A5 وتحس انها ما تصدق انك نسيت و تروح معطله نفسها
رقم العضوية : 37364
الاقامة : HARAM
دراجة بخارية: non
أنا محتاج فادي عزت يشوف الموضوع ده.عشان نعرف مين اللي عنده المصداقية في الحوار ده.أسطي عصام!!!! ولا الشركة نفسها
رقم العضوية : 25539
الاقامة : el-obour
السيارة: bmw e46 330
السيارة[2]: Mercedes c200 kompressor
ههههههههه اكيد اسطى عصام
ومش هو لوحدة كمان
انا مازلت مقتنع بالى انا عارفة وبكرة تشوف
دة ارتوك ياباشا مش هزار
[rmade]http://www7.0zz0.com/2014/09/24/17/941743282.jpg[/rmade]
رقم العضوية : 37364
الاقامة : HARAM
دراجة بخارية: non
وأنا ما زلت عند وعدي بردو.لو التكييف جراله حاجة لا قدر الله هبيع العربية كلها.
علي فكرة أنا كمان مقتنع جدا باللي أنا أعرفه لأنه برده مبني علي حقائق بنسبة أكبر من اللي إنت بتحكي فيه.وزي ما قولت,,مش معني إن 50 عربية ظهر فيهم مشكلة في التكييف.يبقي ده إسمه عييب شائع..
وعلي كل بردو نستني رد خالد أيمن ومحمد عباس لأن دول حافظين العربية دي أكتر من اللي صانعها نفسه
رقم العضوية : 37846
الاقامة : egypt, giza
السيارة: Soon Isa
السيارة[2]: Octavia A5
دراجة بخارية: لازم اكتب حاجه هنا بالعافيه !
العربيه معايا من شهر 2/2009 و ما شاء الله التكيف تلاجه و مفيش اى عييب و فعلا العيب ده من 2007 اختفى و بشهاده ملاك العربيه من اصحابى
[mtohg=#ff0000]https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-snc6/205347_10150903499579227_1587588698_n.jpg[/mtohg]
رقم العضوية : 97188
الاقامة : DUBAI
السيارة: octavia a5
السيارة[2]: octavia a5
دراجة بخارية: Honda cbr 400
يا جماعة ارجوكم فيدونى فى موضوع الفالف بادى ده انا عربيتى ايه فايف وماشية 51 الف بس ولقيت العربية بتنتش فى الغيارات من الاول للتانى ومن الخامس للسادس احيانا فرحت سالت قالولى لازم تغير الفالف بادى فهل فى حل تانى لو غيرت الزيت والفلتر ولا ايه
وهل ينفع اصلح الفالف بادى ده ولا لازم يتصلح
