رقم العضوية : 21058
الاقامة : الهرم
السيارة[2]: kia cerato 2010 gulf
رقم العضوية : 118356
الاقامة : الهرم
السيارة: kia rio
السيارة[2]: Kia cerato Highline S/R
الاقامة : الهرم
السيارة: kia rio
Section Width
The first section of each number, consisting of three digits, stands for the section width of the tire. This is the measurement in millimeters of the widest point of the tire's outer sidewall to the widest point of its inner sidewall. Thus, a tire with the 215-50-17 in......ion has a section width of 215 mm, while a tire with the number 225-55-17 has a section width of 225 mm. In inches, the 215-50-17 tire has a section width of 8.46 inches, while that of the 225-55-17 tire is 8.86 inches.
Sidewall Aspect Ratio
Following the section-width indicator are two digits that stand for the sidewall aspect ratio, or the tire's profile. This is the ratio of the tire size's sidewall, or section height -- which is measured from the rim to the tread -- to the section width, represented as a percentage. Thus, a 215-50-17 and 225-55-17's tire's section height is 50 percent and 55 percent, respectively, of its section width.
Section Height
The tire's section height itself can be determined by multiplying the section width by the percentage figure that the sidewall aspect ratio provides. This results in a section height of 107.5 mm, or 4.23 inches, for a 215-50-17 tire; and a section height of 123.75 mm, or 4.87 inches, for a 225-55-17 tire.
Tire and Wheel Diameter
The third and last numeric section, composed of two digits, denotes the tire and wheel diameter, expressed in inches, meant for pairing. The numbers 215-50-17 and 225-55-17 mean that the tire bearing this in......ion is a 17-inch rubber covering fitted on a 17-inch wheel. The 17-inch tire and wheel is most commonly applied on personal or family automobiles such as cars, minivans and sport utility vehicles.
Read more: The Difference Between 215-50-17 Vs. 225-55-17 | eHow.com The Difference Between 215-50-17 Vs. 225-55-17 | eHow.com
رقم العضوية : 58100
الاقامة : السعوديه
السيارة: not yet
السيارة[2]: ..
http://www.nilemotors.net/Nile/288491-a.html
و باذن الله عن نفسى هركب ال 225/45/17 عشان اداء الفرامل يتحسن شويه .لان دى من عوامل الامان .
و كمان هيزود الثبات حاجه بسيطه .و ايضا العربيه هتنعم شويه عن الاول و لكن اقل حاجه بسيطه من ال 215/50/17
و الله اعلم
لو عاوز تنعم العربيه اكتر هات ال 215/50/17
ربنا معاك و متنساش التقرير بعد التركيب .
إنا لله وإنا إليه راجعون
ولا تحسبن الذين قتلوا في سبيل الله أمواتا بل أحياء عند ربهم يرزقون
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
