النتائج 1 إلى 10 من 13
    الصورة الرمزية yasser dyboo
    رقم العضوية : 139455
    الاقامة : القاهره
    السيارة: رينو نيو لوجان 2015
    السيارة[2]: سكودا
    الحالة : yasser dyboo غير متواجد حالياً
    افتراضي ظبط الاضاءه للفليشيا - Facebook Twitter whatsapp انشر الموضوع فى :
    ده موضوع لقيته وانا بدور علي النت عن ظبط الاضاءه الخاصه بالفليشيا
    حسيت ان الموضوع مفيد انا لسه مشتغلتش فيه او جربته بس قلت انقله ليكم ونناقشه مع بعض يمكن نوصل لتعديل او فائده تعم للكل ان شاء الله
    همه بقي خبراء اسكودا
    A common problem with the Skoda Felicia is the loss of the internal adjustment on the headlight system and the aim being too low with insufficient adjustment on the thumbwheels to correct this leading to an MOT fail.
    This is caused by the loss of hydraulic fluid from the headlight adjustment system which can only be remedied with the replacement of the whole system.
    An alternative to this is to alter the adjustment mechanism so that the thumbwheels adjusters can be used. The headlights can then be adjusted using the thumbwheels which are fitted to the top of each side of the headlight unit. The outer ones alters the headlight beam vertical aim and the inner ones the horizontal aim.
    The photo shows the back of the left hand headlight and the various adjusters. The right hand side is a mirror of this although to gain access you will need to unclip and remove the top of the air filter.
    The next photo shows the adjuster mechanism removed. It is held in place by a bayonet style clip so simply twist and pull out of the headlight to remove. To allow more adjustment on the thumbwheels the nut need to extend further form the adjuster.
    If you simply try to unscrew the nut it may turn the internal of the adjuster at the same time. To prevent this pull the nut in one hand while holding the adjuster in the other. You may need to grip the nut with pliers to do this. Then with your third hand clamp the plastic with another set of pliers. You can now simply unscrew the nut. Once you have unscrewed it put the adjuster back in the headlight and see if the adjustment is within range. If not simply remove and unscrew the screw a little more.
    الصورة الرمزية sakr_skoda
    رقم العضوية : 109920
    الاقامة : مصر
    السيارة: ربنا يبعت
    السيارة[2]: skoda
    دراجة بخارية: لالالالالالالالالالالالالالالالالالا
    الحالة : sakr_skoda غير متواجد حالياً
    ايه علاقة الصورتين دولا بتعديل اضائة الفليشيا ياراجل انا افتكرت نعدل الاضائة بتركيب لمبات اشعة تحت الحمراء علشان نشوف فى الضلمة من غير ما حد يشوفنا ........................
    اللى فى الصور دى خصيصة لسيارات بلاد السلج وتقريبا ملغيا عندنا كلنا ودى مضخاء رزاز ماء ساخن على جدار زجاج الفانوس من الداخل لإذابة السلوج المتراكمة على الكشافى التى تؤدى الى انعدام الرؤية....
    ها ايه رئيك نشغلهم فى مصر يمكن يزوبو المطبات فى شوارع المحروسة....*
    [rmade]http://im60.gulfup.com/1KWugz.jpg[/rmade]
    الصورة الرمزية أحمد جودة
    رقم العضوية : 95704
    الاقامة : cairo حلوان
    السيارة: BMW إنشاء الله
    السيارة[2]: سكودا فليشيا 96
    الحالة : أحمد جودة غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة sakr1964 مشاهدة المشاركة
    تمام الكلام ياعم استاذ صبحي
    وسبحان الله هما بيحاولو يزودو درجة الحرارة فى كل حاجة فى العربية
    واحنا هنا بنسايس العربية علشان ماتسخنش
    مع تحياتي / أحمد أبو ميزو
    [img2]http://www5.0zz0.com/2014/05/05/06/544429690.jpg[/img2]
    الصورة الرمزية I.ABUBAKR
    رقم العضوية : 97715
    الاقامة : alexandria
    السيارة: ??
    السيارة[2]: 97 felicia
    الحالة : I.ABUBAKR غير متواجد حالياً
    يا جماعه الموضوع ده لضبط اتجاه الاناره
    في 3 رجلاش لكل فانوس تقدر تضبط منهم اتجاه الاشعه الخاجه من الفانوس
    رجلاش فوق علي يمين للضبط في المستوي الافقي
    رجلاش فوق علي اليسار لضبط في المستوي الرئسي
    والرجلاش السفلي لضبط عاكس الفانوس للامام والخلف حتي الحصول علي الاضاءه الافضل
    وعلي فكره انا مقرأتش الكلام وترجمته ولكن كل فتره بضبط اضاءه الفوانيس بنفسي
    eacho22 سابقا
    رقم العضوية : 97715
    السيارة: ??
    الصور فعلا بتبين الرجلاش الخاص بضبط الاضاءه
    واي عربيه كل فتره بتحتاج تضبط اتجاه ضوء المصابيح الاماميه للحصول علي افضل رؤيه
    والاوبشن الخاص بتنظيف الفوانيس ده بيبقي رشاشات مياره خارجيه امام الفانوس وده مبينزلش اصلا في العربيات الموجهه لافريقيا ودول الخليج
    eacho22 سابقا
    رقم العضوية : 97715
    السيارة: ??
    وبالمناسبه الرجلاش الثالث الخاص برفع وخفض اتجاه الااره ليه تحكم داخلي عن طريق المفتاح الدوار الموجود اسفل زر نور الطابلوه بس طبعا محدش هيلاقيه شغال
    لان هتلاقي الخراطيم فقدت السائل الخاص بها
    وعلشان تغير الوضع هتضطر تعمله مانيول
    eacho22 سابقا
    الاقامة : القاهره
    السيارة[2]: سكودا
    اقتباس المشاركة الأصلية كتبت بواسطة i.abubakr مشاهدة المشاركة
    شكراا لمرورك
    مش كده برضه انا قريت الكلام ومفيهوش اي حاجه عن تنظيف او ثلوج
    بس انهارده هلعب فيهم شويه واشوف النتيجه واهي تجربه
    الاقامة : مصر
    السيارة: ربنا يبعت
    السيارة[2]: skoda
    حصل لبس عند الاخوة وخصوصا الاخ ابو بكر على فكرة اللى فى الصورة دى مش هيا اللى بتظبط ارتفاع او انخفاض الاضائة اللى بيتكل عنهم دولا حاجة تانية خالص موجودة فى الفوانيس وانا شخضيا بظبط اضائة الكشافات ولازم يكون على جدار منزل او اى شى عاكس حتى تتمكن من ضبط اتجاه النور بالطريقة الصحيحة اما اللى فى الصوره دى زى ما شرحت سابقا وممكن تتاكدو من الخرطوم الازرق الرفيع افتكر تدا دليل ان الخرطوم لمرور ماء او سائل مش نور وانا مش بتكلم اى كلام وخلاص انا فكيت فعلا الجزء دا واتعرفت على ميكانيزم عمله لأنى ببساطة باحب اتعرف على كل شئ فى السيارة حتى ولو لم استعمله....
    رقم العضوية : 97715
    السيارة: ??
    طيب يا عم صقر فيه في اول صوره فوق 3 رجلاش يا ريت توضحلنا ايه فايدتهم
    مع العلم ان انا عن نفسي بضبط من خلالهم اتجاه الاضاءه ومستوي ارتفاعها
    ولو فيه طريقه اخري لضبط الاضاءه يا ريت توضحها
    وشكرا مقدما
    eacho22 سابقا
    الاقامة : مصر
    السيارة: ربنا يبعت
    السيارة[2]: skoda
    وشكرا مقدما
    مظبوط الصورة الولى فيها بكرتين واحدة على الشمال والتانية على اليمين دولا لظبط زواية الكشاف على فكرة انا كسرت كشاف علشان اعرف هما بيشتغلو ازة....*
    على العموم شوف بقى الجزء الاسود اللى فيها خرطوم ازرق حاول تحركة وشوف النتيجة حنروح بعيد لييييييييييييييييييييه
  1. الاضاءه زفت
    بواسطة ehab1eg في المنتدى قسم الإضاءة والفوانيس وتعديلاتهما
    آخر مشاركة: 01-10-2012, 01:57 PM
  2. سؤال هام فى الاضاءه و الفوانيس
    بواسطة hamada_amg في المنتدى هـــــــوندا
    آخر مشاركة: 25-09-2012, 01:39 PM
  3. كيفيه تحسين الاضاءه
    بواسطة rasboten في المنتدى قسم الإضاءة والفوانيس وتعديلاتهما
    مشاركات: 16
    آخر مشاركة: 10-11-2011, 03:06 PM
  4. طريقه ظبط الاضاءه
    بواسطة Electric في المنتدى كــماليــات السيـــارات و الإكسسوارات
    مشاركات: 10
    آخر مشاركة: 10-07-2010, 10:27 PM
  5. الاضاءه و الحراره ف الشاهين
    بواسطة ymoniem في المنتدى فــــيات
    آخر مشاركة: 16-07-2007, 09:33 AM
