باشا السعر كام الفين ولا مئتان
رقم العضوية : 10345
السيارة: coupe
السيارة[2]: coupe
دراجة بخارية: لايوجد
الموديل : p500.2 امريكى اصلى made in usa
الحاله : استعمال خفيف وحاله ممتازه وشغال بكل كفاءه
الموديل ده مش موجود فى مصر وكان جاى من امريكا ودى مواصفاته بالكامل :
- 4 ohms: 125 watts x 2 chan.
- 2 ohms: 250 watts x 2 chan.
- Bridged, 4 ohms: 500 watts x 1 chan.
Max power output: 1000 watts x 1 chan.
MOSFET power supply
Remote bass level input (remote level control sold separately)
LED power, thermal, and protect indicators
Tuned Bass EQ (0-18 dB bass boost at 45 Hz or 0-12 dB bass boost at 12 kHz depending on crossover selection)
On-board differential inputs eliminates noise picked up by the signal cable
2/1 channel operation
Integrated Trans•ana technology simplifies the signal path of the amplifier allowing the signal to travel through the amplifier at a lower voltage. The result is greater reliability and exceptional sound quality.
RCA Pass-thru outputs
Featured custom designed TO-247 MOSFETs have 60% more ....l tab area providing more power handling capacity, lower impedance and improved heat dissipation over traditional TO-220 MOSFETs found in most competitor's amps.
Built in NOMAD is a "real time" analog computer that protects your amplifier from shorting speaker wires and dangerously low speaker impedances.
Cast aluminum heatsink evenly distributes excess heat across entire amplifier heatsink
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable high-pass filter (50-500 Hz, 12 dB/octave)
Variable low-pass filter (50-500 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-20000 Hz
Dimensions: 13.02"L x 7.625"W x 2.25"H
السعر : 2000
م : 01009456565
رقم العضوية : 154714
الاقامة : العبور
السيارة: Hyundai Excl
السيارة[2]: 127
رقم العضوية : 134094
السيارة: Skoda Octavia A5 2007
السيارة[2]: BMW M3 2002
اسف السعر كان 2000 بردو وتقريبا اللى انا اقصده ابو 1500 مش نفس اللى انت عارضه بعتذرلك
بس يا ريت تظبط السعر وتبعتلى على الخاص وانا شارى بإذن الله ولو الصب alpine لسه موجود بردو ادينى النهائى على الخاص
وده اللينك صح كده
https://egypt.dubizzle.com/ar/cars/c...ljZV9fZ3RlPQ==
حسبى الله لا إله إلا هو عليه توكلت وهو رب العرش العظيم
(لا إله إلا الله سيدنا محمد رسول الله)
رقم العضوية : 85958
الاقامة : Egypt - Faisl
السيارة: Verna , 1.5 , M/T
السيارة[2]: Toyota Yaris , 1.3 , A/T
رقم العضوية : 10345
السيارة: coupe
السيارة[2]: coupe
تمام يباشا هو ده الجى ام اللى معروض فى اللينك
رقم العضوية : 10345
السيارة: coupe
السيارة[2]: coupe
تم تعديل السغر الى 1500
وده عشان انا اشتريت ال power من البانش وبالتالى ده مركون بدون شغل عندى
على فكره انا لقيت منه ال p200 عند السجان فى المهندسين عامل 1200 جنيه
بتهيألى كده السعر مش مبالغ فيه ولقطه للى هيكون من نصيبه باذن الله
العرض ده سارى لفتره محدوده؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟ ؟؟؟؟
رقم العضوية : 10345
السيارة: coupe
السيارة[2]: coupe
للرفع.....................
رقم العضوية : 10345
السيارة: coupe
السيارة[2]: coupe
طيب نخش شويه فى التقيل :
t600-2 وده طبعا موديل ال power من البانش
ومعروض للبيع برده بس بصراحه المشكله فى اللى فاهم معناه وسعره كام؟؟؟؟؟ الجى ام بحاله الزيرو ومعاه الكرتونه
مواصفاته وسعره هنا : Rockford Fosgate T600 2 Power 600 Watt 2 Channel Class AB Car Audio Amplifier 0780687324476 | eBay
رقم العضوية : 10397
السيارة: Chevy Aveo 2008
السيارة[2]: Emgrand EC7 2015
دراجة بخارية: Suzuki Boulevard
الشهادة بتاعته فيها كام واط ؟
ومطلوب فيه كام ليا انا :)
باتكلم عن الـ t600 طبعا ^_^
