الكلام ده مش موجود في العربية اللي في السوق المصري يا عمونا
رقم العضوية : 144794
الاقامة : الشرقية
السيارة: لا يوجد
السيارة[2]: VW beetls 1982
للأسف المعلومات جبتها من كتالوج أجنبى و محتاجين حد يترجمها للناس عشان مهمة جداً و أنا مش عندى وقت أترجمها :
[justify]
Engine Oil Life System
When to Change Engine Oil
This vehicle has ( the Engine Oil Life System ), a computer system that indicates when to change the engine oil and filter.
This is based on engine revolutions and engine temperature, and not on mileage. Based on driving conditions, the mileage at which an oil change is indicated can vary considerably.
For ( the oil life system ) to work properly, ( the system ) must be reset every time the oil is changed. When ( the system ) has calculated that oil life has been diminished, it indicates that an oil change is necessary. A change engine oil light displays. Change the oil as soon as possible within the next 1 000 km (600 miles).
It is possible that, if driving under the best conditions, ( the oil life system ) might indicate that an oil change is not necessary for up to a year.
The engine oil and filter must be changed at least once a year and, at this time, ( the system ) must be reset.
Your dealer has trained service people who will perform this work and reset ( the system ). It is also important to check the oil regularly over the course of an oil drain interval and keep it at the proper level.
If ( the system ) is ever reset accidentally, the oil must be changed at 5 000 km (3,000 miles) since the last oil change. Remember to reset the oil life system whenever the oil is changed. How to Reset the Engine Oil Life System Reset the system whenever the engine oil is changed so that ( the system ) can calculate the next engine oil change.
To reset the system:
1. Turn the ignition to ON/RUN, with the engine off.
2. Fully press and release the accelerator pedal three times within five seconds.
3. Turn the key to LOCK/OFF.
If the change engine oil light comes back on when the vehicle is started, the engine oil life system has not reset. Repeat the procedure.[/justify]
رقم العضوية : 10397
السيارة: Chevy Aveo 2008
السيارة[2]: Emgrand EC7 2015
دراجة بخارية: Suzuki Boulevard
رقم العضوية : 34925
النوع : انثى
السيارة: 84474662669
السيارة[2]: lanos Model 99 1.6 16 v
دراجة بخارية: N/A
الكلام دا كبير أوى ومعناه المختصر ان ميعاد تغيير الزيت هيكون حسب كفائته وليس عدد الكيلومترا المقطوعة.. ودا بيتم عن قراية حساسات فى الماتور وهو بيديك تحزير بتغيير الزيت خلال 1000 كيلو
وفيه فى آخر الموضوع كيفية عملت ريست لنظام متابعة الزيت
اللى محتاجينه بقة من ملاك الافيو هو معرفة هل الطريقة دى تنفع عندهم ولا لأ.. والحاجة الأهم بما إن ماتور الأفيو هو هو ماتور الانوس ماعدا التغيرات الطفيفة هل ينفع فيها الكلام دا ولا لأ..؟؟؟
وبالتالى هل الطريقة دى تنفع لكل مواتير gm...؟؟؟؟
شكرآ على المقالة وفعلآ مهمة جدآ
الاقامة : الشرقية
السيارة: لا يوجد
رقم العضوية : 285
السيارة: Cruze
السيارة[2]: kia cerato 2011 SX
الكلام ده لو عندك كمبيوتر بيطلعلك انك لازم تغير زيت لما يجيى معاده..مش عندنا
[img3]http://indianautosblog.com/wp-......./uploads/2009/12/Chevrolet-Cruze-Irmscher.jpg[/img3]
الاقامة : الشرقية
السيارة: لا يوجد
رقم العضوية : 285
السيارة: Cruze
الاقامة : الشرقية
السيارة: لا يوجد
رقم العضوية : 285
السيارة: Cruze
