. The light blinks in green when the IntelligentKey battery is running out of power. Replacethe battery with a new one. (See “KEYBATTERY REPLACEMENT†in the “8. Main-tenance and do-it-yourself†section.)
. The light illuminates in yellow when it warnsof a malfunction with Intelligent Key system.If the warning light illuminates in yellow while theengine is stopped, it may be impossible to startthe engine. If the light comes on while the engineis running, you can drive the vehicle. However inthese cases, contact a NISSAN dealer for repairas soon as possible.
مختصر الكلام لو بينور اخضر يبقي فيه مشكلة في بطارية المفتاح بدأت تخلص
لو بينور اصفر يبقي فيه مشكلة في السيستم وتروح التوكيل
