Factory Recalls
  • Factory Recalls
    السيارات التي تم سحبها نتيجة لوجود عيوب فيها :-
    ألفاروميو
    A156,A147 10,2000 - 10,2003
    hood lock
    A159 07. - 08,2006 roof railing
    أستون مارتن
    Vanquish 2001 - 2005 accelerator pedal
    أودي
    A3 2006 Gas cartridge Head Airbag
    A3 06,2003 - 06,2004 clutch
    A3 04,2003 cooling exhausts
    A4 2002 - 2003 emergency brake
    A4, A6, A8 1994 - 1999 support arms front axle
    A4, S4 Cabriole 2003 - 2004 xenon headlights
    A6 02,2004 - 03,2005 software Airbag
    A8 2002 - 03,2004 driver Airbag
    ينتلي
    Arnag 2005 and 2006 wheel nuts
    Continental GT 2003 - 03,2004 brake hose
    بي ام دبليو
    118d, 120d, 318d, 320d 08,2004 - 03,2005, 12,2004 - 03,2005 generator screw connection
    120d 03/2007 to 05/2007 injection
    3er 01,1998 - 02,2001 rear axle suspension
    5er 06,2003 - 07,2003 tears windshield
    5er, 6er, 7er, X5 13.05.2004 - 12.07.2004 motor control
    5er, 7er 02,2003 - 06,2004 seat heating
    5er Touring 09,1995 - 06,1996 steering wheel lock
    M3 09,2000 - 2004 oil pumps bearing failure approx
    X3 3.0d 01,2004 - 06,2004 oil leakage of the power steering
    X5 08,1999 - 12.04.2002 brake hose
    X5 10,2003 - 04,2004 motor control
    كاديلاك
    CTS, SRX, XLR 2004 wheel suspension
    سيتروين
    C2, C3 to 11,2003 coil springs in front
    C2, C3, C4, Xsara Picasso, Berlingo coolant temperature sensor
    C3 15.09.2002 15.01.2003 short circuit ABS controller
    C4 06,2005 09,2005 brake assembly rear wheel
    C4 1,6 HDi 2005 starter cables
    C4 1,6 HDI, C5 1,6 HDI, Xsara Picasso 1,6 HDI 07,2004 12,2004 Leakage fuel pipe
    C8 06 Xsara Picasso combination instrument 2002 11,2004 lower hood cover, expiration of condensation air conditioning system
    كرايسلر
    300C 10/2006 11/2006 ABS controller
    Grand Cherokee 2000 2001 Tie rod
    PT Cruiser 2001 2004 Hydraulic hose
    PT Cruiser 2005-2006 Triangle windows
    Sebring 10,2004 11,2004 Seat belt attachment under
    Sebring 10/2006 11/2006 ABS controller
    Voyager 1996 2000 Driver airbag
    فيراري
    F360 2003 to 2004 hydraulic leakage servo pump
    فورد
    Explorer 04.1997 11.1998 Cruise control
    focus, focus C-max OF 02.2004 03.2005, 02.02.2004 03.03.2004 leakage rear windshield wiper engines
    Galaxy 11.2002 08.2003 clutch
    Maverick 2001-2004 ABS
    Maverick 2002 2004 gas course
    Mondeo 06.2004 07.2004 chassis sensor
    Mondeo 6.2. 8.9. 2006 damming material particle filters
    S-max, Galaxy 10.04.2006 31.05.2006, 01.02.2006 11.06.2006 engine control software, fuel pipe
    S-Max/Galaxy 12.2005 tons of 06.2006 bonding windshield heating
    فيات
    Multipla 1,9 multi-jet April 2005 until January 2007 fire risk of the thermic protection mat
    Panda 09,2003 to 11,2006 engine equipment
    Panda, Punto, Stilo, Idelo 08,2005 05,2006 w heel
    Punto 1999 2003 break trailer coupling
    Punto 1995 1999 brake hose
    Scudo 2,0 JTD 01,2005 02,2005 negative pressure hose brake booster
    Stilo 02,2001 12,2003 steering housings
    Stilo 10,2001 07,2002 Airbag
    Stilo autumn 2001 20.09.2006 front wheel springs
    Ulysse 06,2002 11,2004 lower hood cover, condensation air conditioning system
    Ulysse 08/2002 to 12/2004 brake booster
    هيونداي
    matrix, Accent 01,2001 10,2002 Diesel fuel line
    جاجوار
    S-type and XJ 2005 to 2007 particle filters
    XJ 07,2005 01,2006 Sun roof
    XJ, XK 1997 1999 butterfly valves k.A.S
    جيب
    COMM other 10/2006 12/2006 ABS controller
    compass 09/2006 11/2006 ABS controller
    Grand Cherokee 2003 2004 seat heating
    Grand Cherokee 10/2006 12/2006 ABS controller
    Wrangler 11,2005 02,2006 coupling rod
    Wrangler 11/2006 12/2006 ABS controller
    كيا
    Rio 05,2000 03,2004 fuel pipe
    Rio, Carens, Carnival 2003 ABS
    Shuma, Sportage 1995 1998 seat harness release
    Sorento 2002 2005 Generator
    Sorento 12,2003 04,2004 automatic transmissions
    Sorento before that 05.03.2004 oil cooler line
    Sportage 03,2005 05,2005 emergency brake
    لانشيا
    Lybra 10,2000 10,2003 hood lock
    Musa, Ypsilon 08,2005 05,2006 wheel 11,560 (see also Fiats)
    Musa, Ypsilon 03,2005 welding seam front axle cross beam
    Phedra 06,2002 11,2004 lower hood cover, expiration of condensation air conditioning system
    Phedra 2003 brake hose approx.
    Ypsilon 11,2005 05,2006 air conditioning system
    لاندروفر
    Discovery, Defender 09,1998 12,2003 ABS
    Rover sport model year 2005/2006 wires
    Rover sport Discovery 08,2005 09,2005 seat stand
    لكزس
    LS of 430 29.07.2003 14.01.2004 transmissions
    RX of 300 02,2003 12,2004 master brake cylinders stop light switches
    RX 300, RX 400h 03,2003 05,2005 carpet tie-clips
    مازدا
    M3 06,2003 03,2004 Airbag sensor
    323 12,2002 engine warning lamp
    5,2,0 MRZ-CD 03.10.2005 29.12.2005 screw connection cam shaft sensor plate
    6 11,2002 climatic compressor
    6 14.2.2002 13.5.2003 brake control light
    6, MPV, MX-5 2003 fog headlights
    MPV 6, Premacy 04,2001 to 06,2002 Airbag control unit screw connection wheel
    MPV 2,3 02,2002 12,2004 power steering
    MX-5 12,2005 02,2006 Airbag control module
    RX-8 07,2003 08,2003 heat shield
    RX-8 08,2003 07,2005 thermal insulation above exhaust system
    of tributes 05/2000 to 12/2003 abs controller
    of tributes 05,2001 12,2003 gas course
    of tributes 31.05.2001 seat harness release
    مرسيدس
    A, B, C-class 05 ,2005 05,2006 connecting cable of the combination switch
    A-class, Vaneo 04,2002 04,2003, 04,2002 03,2003 wiper arms
    all models with 6 and 8-zylinder 06,2001 11,2004 voltage regulators, generator
    C-class, CLK class, E-class 08,2003 10,2003 seat harness release
    CL-class, S-class 1998 10,2000 blowers for heating
    E-class, CLS class 01,2002 01,2005 battery controller
    E-class, CLS class, SL-class 06,2001 03,2005 brake assembly
    E-class, SL-class 2002 2004, 2001 2004 SBC brake system
    G-class 04,2006 11,2006 Differtiallock
    M-class 05,1998 12,2002 clip at the steering element hose
    R 350 07.08.2005 15.02.2006 wires
    R-class 03.01.2006 04.03.2006 Seat belt lock in the back
    SLR 1 0,2003 generator
    Sprinter 2006 wheel flanges
    Vito, Viano 09,2005 02,2006 software faults
    Vito, Viano 10,2003 11,2005 gasoline line
    Vito, Viano 11,2003 04,2004 software motor control
    Vito, Viano 3,0 CDI 03,2006 09,2006 trunk circuit starter
    ميني
    Cooper, Cooper S 21.08. 14.11.2006 roof problem
    Cooper S John Cooper Works GP kit 26.04.2006 27.06.2006 cracking in the rims
    ميتسوبيشي
    Galant 08,1996 03,2001 front wheel suspension
    Grandis 2006 back seats
    L200 03,2006 water sensor
    Lancer 1992 1993 rear flap
    Pajero automatic transmission 11/2006 03/2007 bell crank automatic transmission switching rope
    نيسان
    Almera Tino 11,2002 11,2003 attachment of coverings
    Almera, X-Trail 07,1999 02,2001, 12,2000 12,2002 open-loop system tension adjusters
    Micra 02,2004 09,2004 water entrance rear flap switch
    Micra 11,2002 12,2004 I-key-system
    Murano 04,2002 11,2005 tank
    Murano 04,2002 07,2005 three point static belt in the back
    Navara 05,2005 19.12.2005 wheel bearings rear axle
    Navara 02,2005 09,2005 cardan shaft attachment note
    Pathfinder 02,2005 09,2005 cardan shaft attachment
    Qashqai 2007 Head Airbag holder
    Qashqai to 2.3.2007 rear flap lock
    Qashqai to 7.2.2007 wishbones front axle
    Qashqai 12.2. 05.3.2007 wishbones rear axle
    X-Trail 06,2000 11,2004 tank filler supports
    X-Trail, Primera t o 09,2002 controller
    X-Trail, Primera, Almera, Almera Tino 01,2003 09,2005 load pressure sensor motor control
    X-Trail, Primera, Almera, Almera Tino 2 001 30.09.2002 number of revolutions sensor
    أوبل
    Antara 2006 locking clip brake pedal
    Astra 2004 2005 joint front axle
    Corsa starting from 10.2006 wishbones front axle
    Signum 2005 2006 disk wash nozzle
    Sintra 1996 1998 Steering bolt
    Vectra 2005 2006 disk wash nozzle
    Vectra 2006 seat belt in the back
    Vectra (B) 2002 exchange steering gears
    Zafira 2005 2006 CNG system, air conditioning system ECC
    بيجو
    1007 k.A. combination instrument
    206 SW 08,2003 02,2004 tail spoiler attachment
    307 02,2002 09,2005 ABS controller
    307 to 06,2003 corrosion servo-pump
    307 03,2004 06,2004 support arm safety device
    307. 406, 607, 807 06,2001 10,2002, 05,1999 10,2004, 10,1999 09,2004, 06,2001 06,2003 motor control
    406 2002 electrical motor radiator fan
    406,2,0 HDI, 406,2,2 HDI, 607,2,2 HDI 11,1999 09,2003 g low relays
    of 407 10,2004 04,2005 coolant level givers
    407,1,6 HDI 12,2004 07,2005 shift pipe
    of 607 01,2001 11,2002 battery cables
    of 607 05.03.2001 26.08.2001 wishbones in the back
    807 06,2002 11,2004 lower hood cover, condensation air conditioning system
    807 05/2001 11/2004 single solenoid valves brake booster
    بورشه
    P 911 Cabrio (993) 08,1993 01,1998 cover
    Carrera S, Carrera 4S 04,2004 10,2005 exhaust of welding seams
    Cayenne 01.10.2002 17.12.2003 rear seat harness releases
    Cayenne 01.10.2002 19.07.2003 wiring harness
    رينو
    Clio 08.05.2003 18.10.2005 wires horn
    Clio 07. 09.10.2002 front wheel suspension
    Clio, Megane 10.11.2005 29.05.2006 controller of the automatic transmission
    Espace 01.09.1996 11.12.1998 spare wheel mounting plate
    Laguna 18.07.2001 15.05.2002 ABS, ESP
    Laguna 01,2001 10,2002 fuel injection system
    Laguna II, Vel Satis, Espace IV to 05.04.2005 recycling of exhaust gases valve
    Laguna, Vel Satis, Espace 03,2001 03,2004, 10,2004 02,2005, 10,2002 02,2004, 10,2004 02,2005 clutch master cylinders;
    Mégane CC 10,2003 07,2005 A-column-cover 14,550
    Mégane CC 09,2003 06,2004 Hardtop
    Mégane II 19.10.2002 30.12.2002 b rake
    mode to 05.04.2005, 14.09.2004 24.10.2004 steering column, real axle springs
    Scénic to 12,2005 seat harness releases
    Scénic 2003 26.01.2004 brake pedal carriers
    Scénic June 2006 steering column Vel Satis since commencement of production engine sensors
    Vel Satis, Espace 0 1,2002 12,2005, 01,2002 11,2004 motor control, cooling agent header tank
    رولزرويس
    phantom 01,2006 03,2006 shock absorbers
    روفر
    ROVER 75 10,1999 02,2002 wheel suspension
    ساب
    SAAB 9-3 11,2005 wheel bearings
    9-3 1.8t, 9-3 2.0t, 9-3 2.0T 2003 2005 master brake cylinders
    9-3, 9-5 2000 2002 ignition system
    9-5 1998 2003 wheel bolts Seat
    Alhambra 2002 2003 clutch
    Cordoba, Ibiza 2004 head and side airbags
    سمارت
    Forfour 04,2005 09,2005 attachment rear seat surface
    Fortwo 01,2006 04,2006 seat attachment
    Fortwo 1998 2000 support arms front axle
    سوبارو
    Outback, Forester 2001 to 2003, 2003 to 2004 cruise control
    Swift 05,2005 04,2006 clutch
    سوزوكي
    Grand Vitara 1,9 DDiS JT 12,2005 08,2006 load air tube
    Grand Vitara XL7 2 2.11.2000 25.02.2004 wiring glow relay
    Ignis 2003 2006 p assenger airbag
    Swift 2005 to 2006 parking brake rope
    Swift 2005 master brake cylinders
    SX4 2 006-2007 emergency brake 4090 R Suzuki Vitara V6 1998 2003 pressure control valves gasoline line
    Wagon R+ 2000 2003 gas through train
    Wagon R+ 1,0, Wagon R+ 1,2 1997 2000 switching push pull cable
    تويوتا
    Avensis 06,2004 07,2004 chassis sensor
    Avensis 15.01.2003 05.11.2003 steering element
    Avensis 1,8 VVT i 01,2003 12,2005 steering column
    Corolla 1,4 D-4D, Corolla 1,4 VVT i, Corolla 1,6 VVT i 07,2003 11,2005 steering column
    Corolla 2,0 D-4D, Avensis 2,0 D-4D 02,2003 03,2005 pressure tubing brake booster
    Corolla Verso 01,2004 05,2006 Passenger airbag
    Hilux 07,2005 12,2005 exhaust hose
    country Cruiser of 120 09,2002 06,2005 master brake cylinders
    Landcruiser 90 04,1996 01,1999 drive shaft flange
    country Cruiser 90 2001 2003 front axle
    Mazda 6 MRZ-CD 03.10.2005 29.12.2005 screw connection cam shaft sensor plate
    Prius 07,2003 11,2005 steering column Prius k.A. stop light switch
    Prius, Yaris, Yaris Verso 02,2001 10,2001 crankshaft sensor
    RAV4 06,2002 09,2004 s teel wheels
    Yaris 11/2005 to 07/2006 rear seat head restraint
    Yaris 11/2005 to 02/2006 front seat head restraint
    Yaris 11/2005 to 02/2006 side airbags in front
    Yaris, Yaris Verso, Celica 2000 2002 master brake cylinders
    فولفو
    C70 2007 left cable door handle
    S40, V40 2003 fuel pipe
    S40/V50 2003 2005 fuel pump
    S40/V50 2004 2005 emergency brake
    S60, S80, V70 2004 screw connection wishbone
    S60, S80, V70, XC70 2000 2001 cooling regulation
    V50 2007 spotwelds in the roof
    XC90 2002 2005 ball joint tie rod
    XC90 2004 wheel number of revolutions sensor
    XC 90 all software 2,500 S Volvo XC90, S80 2005 2006 battery cables
    فولكسفاجن
    Beetle 05,2006 10,2005 combination instrument
    Fox 06,2004 12,2007 hood bolting device
    gulf 11,2006 01,2007 ground wire air additional heating system
    trade wind 2005 2007 wiper engine, owner fuel radiator, vacuum piping
    trade wind of 2006 s oftware faults
    trade wind 08,2003 11,2003 screw at the shock absorber camp
    trade wind 1996 1999 support arms front axle
    trade wind 2,0 TDI 04,2005 05,2005 clutch
    Polo 2006-2007 seat heating
    Sharan 2003 2004 clutch
    Sharan 2001 2005 xenon light,pressure pipe turbo
    T5 California 2004 04,2005 camping gas plant
    T5 Multivan to 08.06.2004 emergency brake
    Taro 1989 1996 steering element
    Touareg 01.10.2002 17.12.2003 rear seat harness releases Touareg wiring harness
    أرجو أني أكون أفدتكم ..
    [SIGPIC]http://imageshack.com/a/img838/5746/61n6.jpg[/SIGPIC]
    افدتنا طبعا تسلم ايدك يا كمارو
    بس اكتر حاجة بتعجبني في الناس دول انهم بيعترفو بأخطأهم مهما كانت صغيرة وممكن تتدارى
    وده يمكن ساهم بنسبة كبيرة في نجاحهم.
    مش زي عندنا يبقى الواحد غلطان من ساسه لراسه ودماغه والف اديداس انه صح
    [COLOR=blue]------------------------------------[/COLOR]
    [RIGHT][FONT=Arial (Arabic)][SIZE=5][SIZE=3][COLOR=blue]وليد عبد العزيز[/COLOR][/SIZE][/SIZE][/FONT][/RIGHT]
    [RIGHT][FONT=Comic Sans MS][COLOR=blue]Opel, 1 Team, 1 Goal, 1 Family :friends:[/COLOR][/FONT][/RIGHT]
    [RIGHT][FONT=Comic Sans MS][COLOR=#0000ff]لو لم اكن اوبلاويا لوددت ان اكون اوبلاويا[/COLOR][/FONT][/RIGHT]
      المشاركة الأصلية كتبت بواسطة abdelaziz-waleed مشاهدة المشاركة
      أولاَ شكراَ على الرد الجميل دة ..
      أما بالنسبة للأخطاء فالناس دي حياة البشر عندهم مهمة و أهم من الفلوس العربيات نفسها و هما عارفين إن أقل خطأممكن تروح في أرواح بشر أبرياء علشان كدة الناس دي متقنة جداَ في شغلها و أي خطأ صغير مهما كان بيعملوا أول ما يتعرف له حساب و يسحبوا العربيات علشان يصححوا الأخطاء دي و بتوصل لدرجة أنهم أحياناَ بيعوضوا ملاك السيارات بأموال .. أنا واحد قريبي عايش في ألمانيا عنده عربية AUDI A4 كان شاريها من المصنع بنصف ثمنها لأن كان في واحد إشتراها قبله بس لقى فيها عيب العيب دة إيه ؟! ......... قربة المياه كانت بتخر فرجعها و أخد واحدة تانية ببلاش و بعدين المصنع عالج العيب و باعها بنصف ثمنها .. شوف وصلت لدرجة إيه .. ؟! سبحان الله إحنا بعد الله سبحانه و تعالى عايشين على مجهود الناس دي في العلم و الصناعة ..
        الف الف شكر يا باشا
        بجد مجهود رائع
        [COLOR="Red"][URL="http://www.7abamix.com/2minutes.htm"][SIZE="6"]سبحان الله وبحمده[/SIZE][/URL][/COLOR]
          المشاركة الأصلية كتبت بواسطة Youssef_Mostafa مشاهدة المشاركة
          الف الف شكر يا باشا
          بجد مجهود رائع
          شكراَ على الرد و إهتمامك ..
            الف شكر على المجهود والحمد لله البروتون مش فيهم ولا بلونيز :)
              الحمد لله ..
              بس شوفت يا باورت الحاجات معظمها تافهة إزاي ..
              يعني لو عندنا في مصر .. أنا مش هكمل أنت عارف الباقي ..
                تسلم ايدك يا كمارو ..
                بس انا مستغرب ان هيونداي اقلهم في استدعاء سياراتها .. طبعا هي و الاستون مارتن !!!!
                  الله دا الحبايب كلهم هنا اهو ههههههههههههههههه
                  شكرا يا كمارو علي الخبر
                    لأ وشوفو الاسباب اللي بيسحبو العربيات عشانها .... ممكن حاجات مش خطيرة بس هما ناس بيخافو علي سمهعتهم
                    غريبة جدا ....
                    الشاهين وال 128 عمرهم ما استدعو اي سيارات ...ممكن يستدعو المشتري عشان نسي يدفع الشاي بتاع العمال :)
                    [SIZE=5][COLOR=blue]يظن الناس بي خيرا وإني ... لأشقى الناس إن لم ترض عني[/COLOR][/SIZE]
                    [SIZE=5][COLOR=blue]ومالي حيــلة إلا رجــائي ... وعفوك إن عفوت وحسن ظني [/COLOR][/SIZE]
                    [SIZE=5][SIZE=3][COLOR=black]محاسب / احمد ابراهيم [/COLOR][/SIZE][/SIZE]
                      هههههههههههه
                      انا وقعت من علي المكتب من الجمله دي يا احمد باشا
                      حرام عليك و الله اللي بتعمله فيا
                        المشاركة الأصلية كتبت بواسطة Hassan Khalil مشاهدة المشاركة
                        مش شرط ان ده يكون ميزة , ممكن يكون عدم اهتمام بالمتابعة و العميل
                          الهوندا فين
                            شكرا يا كمارو باشا.ويا تري استدعوا عربيات في مصر ولا كلها خاليه من العيوب؟
                            bemo,ire
                            [CENTER][SIGPIC][/SIGPIC] [/CENTER]
                              bemo,ire
                              مره واحده سمعت انهم اخدوا ال a class من مرسيدس علشان عدلوها بعد حادث الانقلاب الشهير في 97
