FLUIDE AT 42 Fluid for automatic transmissions. Recommended when the manufacturer requires a DEXRON® III fluid. - ALLISON C4 n° C4-24842997
- BMW group 24 - 3.0
- FORD MERCON® (92) n° M970909
- DEXRON® - III n° G-34196
- MAN 339 type V-1 (ex MAN 339 Type F)
- MAN 339 type Z-1 (ex MAN 339 Type F)
- PSA PEUGEOT CITROEN (ZF 4HP14 & ZF 4HP18)
- VOITH H 55.633535 ZF TE-ML 04D, 09B, 17C
- MB Approval 236.1 and 236.5
- NISSAN
FLUIDE ATX Fluid for automatic or semi-automatic transmissions and torque converters of passenger cars, light commercial vehicles and industrial vehicles, when the manufacturer requires an ATF (Automatic Transmission Fluid) GM DEXRON® IID. Adapted to manual gear boxes when an ATF fluid is required, hydrostatic transmissions, power steering, hydraulic systems when a fluid type GM DEXRON® IID is required.
FLUIDE CC Fluid for automatic or semi-automatic transmissions and torque converters of passenger cars, light commercial vehicles and industrial vehicles, when the manufacturer require an ATF 5Automatic Transmission Fluid) GM TYPE A SUFFIX A (TASA). Adapted to hydrostatic transmissions and MERCEDES manual transmissions requiring a fluid according to sheet MB page 236.2.
