هما دول المض انا شفت الموضوع ده فحته تانيه وعايز اعرف هما دول الي مسمينهم night breaker او حاجه زي كده دول انا لقيتهم ماركتهم philips.
HID conversion kit for every car available. I pride myself in having stock of every kind of bulb at anytime!
Advantages of xenon:
• Easy Conversion:
Kits are fast and simple to install. Just Plug And Play. Plug the HID bulbs in
the old harness where a standard halogen bulb would go into, then connect the wires, secure the ballast and you are done, no cutting or welding. As easy as one two three!
• More Light Output:
A 35Watt HID light source produces up to 3 times the lumens as the light source compared to
a 55W halogen bulb. Pure Sunlight: The color temperature of HID lightning is more closely linked to the color temperature of natural daylight. Halogen lights only appear "yellow".
• Great Visibility:
The combination of more light output and whiter color makes for much better visibility in most night time driving conditions. If you have projectors than these kits will open up an all new level for you.
• Longer Life Time:
HID lamps will last on the average of over 5 times longer than any halogen bulb. HID bulbs also produce less heat than halogen bulbs, so you don't have to worry about your headlight, fog light or harness melting.
Temperatures:
4300k(OEM/Wakala White)
6000k(Diamond White)
8000k(Diamond Blue)
10000k (Ultra Blue)
• Easy Conversion:
• Great Visibility:
• Longer Life Time:
Temperatures:
8000k(Diamond Blue)
10000k (Ultra Blue)
