المواصفات الفنية للشاريد 2008
ENGINE
Type 1KR-FE
Bore/Stroke(mm) 71X84
Capacity (cm3) 998
Compression Ratio 10.5:1
Power KW @ RPM 51@6000
Power HP@ RPM 68.39@6000
Torque NM @RPM 94@3600
Fuel Supply EFI
Fuel Type Unleaded
TRANSMISSION
Type 5 SPEED MANUAL 4 SPEED AUTO
Ratios- 1st 3417 2.731
2nd 1.947 1.526
3rd 1.250 1.000
4th 0.865 0.696
5th 0.707
Reverse 3.143 2.290
Final drive 3.938 4.513
Drive Wheels Front
WHEELS & TYRES
Rim Type Steel
Tyre Size 145/80R13 4J
BRAKES
Front Disc brake with booster
Rear Drums leading and trailing
STEERING
Type RACK AND PINION POWER ASSIST
Turns-lock-lock 3.75
Turning Raduis(m) 8.4m
SUSPENSION
Front Macpherson struts with coil springs
Rear Semi-independent torsion axle beam with coil spring
DIMENSIONS(mm)
Length 3470
Width 1475
Height 1530
Wheelbase 2490
Track Front 1310
Track Rear 1300
Ground Clearance 160
Licensing mass 765 755 AUTO
