.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
كورولا2008 1400 سي سي
المواصفات الفنية :
Engine and transmission
Engine type
4ZZ-FE
Displacement (cm3)
1398
Cylinder configuration
4 in-line
Max. power (kW @ r/min)
71 @ 6000
Max. power (HP @ r/min)
95.21@ 6000
Max. torque (Nm @ r/min)
130 @ 4400
Valve mechanism
16 valve DOHC with VVT-i
Valves per cylinder
4
Bore x stroke (mm)
79.0x71.3
Compression ratio
10.5:1
Fuel supply
Electronic fuel injection (EFI)
Unleaded fuel requirement
Only
Emission control
Catalytic converter
Emission control phase
Euro Step 4
Transmission type
C50
Transmission configuration
5-speed manual
Gear ratios: 1st
3.545
Gear ratios: 2nd
1.904
Gear ratios: 3rd
1.310
Gear ratios: 4th
0.969
Gear ratios: 5th
0.815
Gear ratios: Reverse
3.250
Gear ratios: Final drive
4.529
Clutch diameter (mm)
200
Driven wheels
Front
Wheels and tyres
Wheel type
Steel
Wheel size
6JJ x 15
Tyre size
195/65R15
Spare wheel
In boot (full size)
Brakes
Front
15'' Ventilated discs
Rear
15'' Solid Disc
Anti-lock Braking System (ABS)
Standard
Electronic Brake force Distribution (EBD)
Standard
Emergency Brake Assist System (BAS)
Standard
Top speed (km/h)
170
Acceleration: 0-100km/h (s)
13.0
Acceleration: 0-400m (s)
18.6
Dimensions, capacities, weights and clearances
Length (mm)
4540
Width (mm)
1760
Height (mm)
1470
Wheelbase (mm)
2600
Front track (mm)
1535
Rear track (mm)
1535
Ground clearance, unladen (mm)
150
Seats: Adults
5
Luggage compartment (VDA, dm3, rear seats in use)
450
Load area: Length (mm)
1065
Load area: Width (mm)
1570
Load area: Height (mm)
540
Fuel tank (litre)
55
Gross vehicle mass (GVM, kg)
1735
Towing capacity (kg): Unbraked trailer
450
Towing capacity (kg): Trailer with overrun brake
1000
Angle of approach
14
Angle of departure
18
كورولا 2008 1600 سي سي
المواصفات الفنية :
Engine type
1ZR-FE
Special engine features
The popular 4ZZ-FE engine achieves the EURO IV European emmion standards while maintaining high standards of fuel economy and torque characteristics in the low speed range.
Displacement (cm3)
1598
4 in-line
91 @ 6000
122@ 6000
157 @ 5200
Valve mechanism
16 valve DOHC with Dual VVT-i
Valves per cylinder
4
Bore x stroke (mm)
80.5x78.5
Compression ratio
10.2:1
Fuel supply
Only
Emission control
Catalytic converter
Euro Step 4
Transmission type
C50
5-speed manual
Gear ratios: 1st
3.545
Gear ratios: 2nd
1.904
Gear ratios: 3rd
1.310
Gear ratios: 4th
0.969
Gear ratios: 5th
0.815
3.250
4.529
212
Driven wheels
Front
Performance (Data by Toyota Motor Corporation)
Top speed (km/h)
195
10.4
17.2
والباقي مثل الموديل الــ 1400 سي سي
