النتائج 1 إلى 3 من 3
    الصورة الرمزية blazer
    رقم العضوية : 2282
    الاقامة : Cairo ,Faisal st
    السيارة: كانت lada 2107 1989
    السيارة[2]: Daewoo Nubira2 2005 auto
    الحالة : blazer غير متواجد حالياً
    افتراضي A good way to test ur brain ..... it's ok dont feel depressed afterwards !!! - Facebook Twitter whatsapp انشر الموضوع فى :
    [info]copied from my e-mail inbox[/info]
    It's that time of year to take our annual check-up test.
    Exercise of the brain is as important as exercise of the muscles. As we grow older, it's important to keep mentally ...... If you don't use it, you lose it! Below is a very private way to gauge your loss or non-loss of intelligence.
    Take the test presented here to determine if you're losing it or not. The spaces below are so you don't see the answers until you've made your answer.
    OK, relax, clear your mind and begin.
    1. What do you put in a toaster?
    Answer: 'bread.' If you said 'toast,' give up now and do something else.
    Try not to hurt yourself. If you said, bread, go to Question 2.
    2. Say 'silk' five times. Now spell 'silk.' What do cows drink?
    Answer: Cows drink water. If you said 'milk,' don't attempt the next question. Your brain is over-stressed and may even overheat. ....... yourself with reading a more appropriate literature such as Auto World. However, if you said 'water', proceed to question 3.
    3. If a red house is made from red bricks and a blue house is made from blue bricks and a pink house is made from pink bricks and a black house is made from black bricks, what is a green house made from?
    Answer: Greenhouses are made from glass. If you said 'green bricks,' why in the world are you still reading these???
    If you said 'glass,' go on to Question 4.
    4.. It's twenty years ago, and a plane is flying at 20,000 feet over Germany (If you will recall, Germany at the time was politically divided into West Germany and East Germany.)
    Anyway, during the flight, two engines fail. The pilot, realizing
    that the last remaining engine is also failing, decides on a crash landing procedure. Unfortunately the engine fails before he can do so and the plane fatally crashes smack in the middle of 'no man's land' between East Germany and West Germany. Where would you bury the survivors? East Germany, West Germany, or no man's land'?
    Answer: You don't bury survivors.
    If you said ANYTHING else, you're a dunce and you must stop. If you said, 'You don't bury survivors', proceed to the next question.
    5. Without using a calculator - You are driving a bus from Lon don to Milford Haven in Wales. In London, 17 people get on the bus. In Reading, six people get off the bus and nine people get on. In Swindon, two people get off and four get on. In Cardiff, 11 people get off and 16 people get on. In Swansea, three people get off and five people get on
    . In Carmathen, six people get off and three get on. You then arrive at Milford Haven.
    What was the name of the bus driver?
    Answer: Oh, for crying out loud!
    Don't you remember your own name? It was YOU!!
    Now pass this along to all your friends and pray they do better than you.
    PS: 95% of people fail most of the questions!!
    قول الرسول صلى الله عليه وسلم: "خير النساء من إذا نظرت إليها سرتك، وإذا أمرتها أطاعتك، وإذا أقسمت عليها أبرتك، وإذا غبت عنها حفظتك في نفسها ومالك"
    -- اللهم ارزقنيها --
    الصورة الرمزية أبو إياد
    رقم العضوية : 25425
    السيارة: 1
    السيارة[2]: 1
    الحالة : أبو إياد غير متواجد حالياً
    انا من الـ5% اللى نجحت فى اجابه الاسئله وعلى فكره الاجابه بتاعت السؤال الخامس نور الشريف
    الصورة الرمزية mahmoudafify
    رقم العضوية : 29762
    الاقامة : Faysal-Giza
    السيارة: NA
    السيارة[2]: Toyota echo 2000 HB
    الحالة : mahmoudafify غير متواجد حالياً
    انت نسيت تقول انها لي . اصعدي الي فوق
  1. Crash Test 2011 - 2012 Peugeot 508 (Full Test) Euro NCAP
    بواسطة Ahmed.Fahmy في المنتدى بيــــجو
    مشاركات: 1
    آخر مشاركة: 08-08-2012, 06:18 PM
  2. Brain Challenge لعبة جامدة قوى تزيد من قوى عقلك و تتدريب لترفع من مستوى التفكير
    بواسطة hotboja في المنتدى المنتــــــدى الاجتمــاعى
    مشاركات: 6
    آخر مشاركة: 29-11-2008, 10:43 AM
  3. If you dont like Automaster Service or any other Service Cen...Please write here why!
    بواسطة egyptianmafia في المنتدى شــيفـرولــيه
    آخر مشاركة: 15-09-2008, 03:12 AM
  4. I want buy a good car
    بواسطة rarosh في المنتدى قســم خاص لطلـبات شــراء الســـيارات و متعلقاتها فقـــط
    آخر مشاركة: 28-05-2008, 10:39 PM
  5. when ur wife asked u about ............Dont
    بواسطة memo_hefnawy في المنتدى المنتــــــدى الاجتمــاعى
    مشاركات: 25
    آخر مشاركة: 28-11-2007, 03:29 PM
