النتائج 1 إلى 7 من 7
    الصورة الرمزية amir_ezzat
    رقم العضوية : 6456
    الاقامة : Sharm El Sheikh
    السيارة: النترا
    السيارة[2]: اوبل فيكترا
    الحالة : amir_ezzat غير متواجد حالياً
    افتراضي Abs-ebd-eps-esp-esp منقوووووووول - Facebook Twitter whatsapp انشر الموضوع فى :
    ABS
    ABS: Antilock Brake System (or Anti-locking Brake System) - enables you to steer whilst keeping the brake pedal full on. Can be felt as a vibration through the pedal when it cuts in. Also useful in stopping in a straight line if one side is on slippery stuff and the other on grippy stuff (non-ABS will tend to spin).
    EBD
    EBD: Electronic Brake Distribution (or Electronic Brake-force Distributor) - alters how much of the brake force goes to the front and how much to the rear. Cars always have more braking on front as if the rears lock before the front then the car will spin. How much braking you can do with the rears depends on how much weight is in the vehicle so EBD dynamically adjusts this balance. Without it, the manufacturer sets up the balance so the rears don't lock when the vehicle is empty which is less braking than is possible when the vehicle is full.
    EPS
    EPS: Electronic Power Steering - enables the amount of assistance with steering to be varied depending on speed and how much you turn the wheel. This means it can give lots of boost when parking the car whilst still giving you a good feel for the road at speed.
    ESP
    As this was asked along with ABS and EBD, I think it might actually be ESP which is asked about.
    ESP: Electronic Stability Program - senses when the car is about to go out of control and can apply an individual brake to a wheel to help avoid the spin. Will not totally prevent the spin but means that it takes more to lose control. Often also used to give traction control where brakes may be applied if a wheel begins to spin due to too much power for the grip. N.B. many cars have TCS (Traction Control System) without having ESP.
    بدون توقيع
    الصورة الرمزية aymansaad
    رقم العضوية : 19101
    الاقامة : السويس
    السيارة: فيات131
    السيارة[2]: فيات125
    دراجة بخارية: vesba
    الحالة : aymansaad غير متواجد حالياً
    معلش يا جماعة ممكن حد يترجمها
    الصورة الرمزية Fadi Ezzat
    رقم العضوية : 25539
    الاقامة : el-obour
    السيارة: bmw e46 330
    السيارة[2]: Mercedes c200 kompressor
    الحالة : Fadi Ezzat غير متواجد حالياً
    اس
    نظام فرامل : الواقية نظام الفرامل (أو المضادة للتأمين نظام الفرامل) -- تمكنك من توجيه مع إبقاء على دواسة الفرامل على كامل. كما يمكن أن يرى من خلال الاهتزاز على دواسة عندما تخفيضات فيها أيضا مفيدة في وقف في خط مستقيم إذا كان أحد الأطراف على الاشياء الزلقة وغيرها من الاشياء على grippy (عدم الحصول وتقاسم المنافع سوف تميل إلى زيادة ونقصان).
    الكبح
    الكبح : توزيع قوة الكبح إلكترونيا (أو قوة الكبح الإلكتروني الموزع) -- كيف يغير كثيرا من قوة الفرامل يذهب إلى الجبهة وكم إلى العمق. سيارات دائما الحصول على مزيد من الكبح على الجبهة كما لو كان يربيه قفل قبل الجبهة بعد ذلك سوف تدور السيارة. كم الكبح يمكنك القيام به مع المؤخرات يعتمد على مقدار الوزن هو في السيارة حتى الكبح حيوي يضبط هذا التوازن. دون ذلك ، يضع الصانع من التوازن بحيث لا يربي قفل عندما كانت السيارة فارغة الكبح التي هي أقل مما هو ممكن عندما كانت السيارة ممتلئة.
    ربحية السهم
    أرباح السهم الواحد : الالكترونية كهربائية -- تمكن مقدار المساعدة مع القيادة لتكون متنوعة اعتمادا على سرعة ومدى تشغيل عجلة القيادة. وهذا يعني أنها يمكن أن تعطي دفعة قوية عندما الكثير من مواقف السيارات في حين لا يزال إعطائك فكرة جيدة عن الطريق بسرعة.
    إسبانيا
    كما سئل هذا جنبا إلى جنب مع تقاسم المنافع والكبح ، وأعتقد أنه قد يكون في الواقع إسبانيا التي هي ردا على سؤال حول.
    اسبانيا : برنامج الثبات الإلكتروني -- الحواس عندما كانت السيارة على وشك أن تخرج عن نطاق السيطرة ، ويمكن أن تنطبق على الفرامل الفردية لعجلة للمساعدة في تجنب الدوران. لن يمنع تماما ولكن تدور يعني أن الأمر يتطلب المزيد من الجهد ليفقد السيطرة. كثيرا ما تستخدم أيضا لإعطاء التحكم في الجر حيث المكابح يمكن تطبيقها إذا كانت العجلة تدور تبدأ نظرا لقوة أكثر من اللازم بالنسبة للقبضة. N.B. العديد من السيارات قد تي سي اس (نظام التحكم في الجر) دون الحاجة اسبانيا
    انا ترجمت من جوجل على طول
    [rmade]http://www7.0zz0.com/2014/09/24/17/941743282.jpg[/rmade]
    الصورة الرمزية NaderNabil
    رقم العضوية : 45
    الاقامة : المعادي..أخر الشارع
    السيارة: Logan A/T-Yaris HB HL
    السيارة[2]: Astra J Cosmo
    دراجة بخارية: NO
    الحالة : NaderNabil غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة Fadi Ezzat مشاهدة المشاركة
    أنصحك تشيل الترجمة دي فوراً...لأنها تعتبر فك شفرة الدخول لمغارة علي بابا...
    بزمتك فاهم حاجة من الل مكتوب؟
    رقم العضوية : 25539
    الاقامة : el-obour
    اقتباس المشاركة الأصلية كتبت بواسطة nadernabil مشاهدة المشاركة
    لأ خالص
    انا لو كنت فاضى كنت ترجمتها انا
    بس انا دلقوتى رايح مشوار وان شاء للة اترجمها لما ارجع
    الصورة الرمزية kemoelord
    رقم العضوية : 6424
    الاقامة : Nasr city
    السيارة: not exist
    السيارة[2]: Mistsubishi-Lancer Ex 09
    الحالة : kemoelord غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة NaderNabil مشاهدة المشاركة
    ههههههههههههههههههههههههه هههههههههههه
    ههههههههههههههههههههههههه ههههههههههههههههههههههههه ههههههههههههههههههههه
    الصورة الرمزية seeker
    رقم العضوية : 48044
    الحالة : seeker غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة amir_ezzat مشاهدة المشاركة
    ABS
    ايه بى اس ABS : نظام مانع الانغلاق . ويسمح للسائق بتوجيه السيارة يمينا او شمالا اثناء الضغط على بدال الفرامل . ويمكنك استشعاره بذبذبات ( او فيبريشن) على دواسة البنزين عندما يبدأ فى العمل ، وهذا النظام مفيد فى ايقاف السيارة فى خط مستقيم لو كان جانب من السيارة يسير على ارض زلقة في حين الجانب الآخر من السيارة يسير على تربة خشنة ( انظمة الفرامل بدون الـ ايه بى اس تفشل فى الحفاظ على سير السيارة بخط مستقيم وقد ندور حول نفسها فى حالة الفرملة)
    EBD
    اى بى دى EBD : نظام توزيع الفرامل الالكترونى - ويقوم بالتحكم والتعديل فى قوة الفرامل الموجهة للعجلات الامامية او العجلات الخلفية
    تحتوى السيارات دائما على فرامل اقوى للعجلات الامامية لانه اذا بدأت فرامل العجل الخلفى قبل العجل الامامى سيؤدى ذلك لدوران السيارة حول نفسها.
    اما عن كمية الفرامل التى يمكن استخدامها للعجل الخلفى فهى تتوقف على كمية ووزن حمولة السيارة . لذلك يقوم نظام اى بى دى ديناميكيا بموازنة وتعديل كمية الفرامل وتوزيعها . وبدونه يضطرمصنّع السيارة الى تهيئة اتزان السيارة بحيث لا تضطر العجلات الخلفية للاغلاق حينما تكون السيارة فارغة وهو مايعنى فرامل اقل مما هو محتمل لو كانت السيارة ممتلئة
    EPS
    اى بى س : EPS نظام توجيه عجلة القيادة الالكترونى ، وهو يسمح ويحدد كمية المساعدة المطلوبة لتوجيه عجلة القيادة لتتغير طبقا لسرعة السيارة وكمية التفاف عجلة القيادة حول محورها . وهذا يعنى انها ممكن ان تساعد بشدة اثناء ركن السيارة وفى نفس الوقت تمنحك شعور جيد للاحساس بالطريق اثناء القيادة بسرعة
    كفاية تعبت بأه . الباقى بعدين
    ESP
  1. هل يستجيب الله دعوتي ولو كنت عاصي؟ منقوووووووول
    بواسطة youssefmustang في المنتدى المنتــــــدى الاجتمــاعى
    آخر مشاركة: 28-06-2010, 06:18 AM
