Notes Specified value Measured value
Lubricants and capacities
Engine oil grade - cold climate SAE 5W/30
Engine oil grade - moderate climate SAE 10W/40
Engine oil grade - hot climate SAE 15W/40
Engine oil classification API/ACEA SJ/A2-96
Engine oil grade - alternative - moderate climate SAE 15W/40
Engine oil classification - alternative - moderate climate API/ACEA SJ/A2-96
Engine with filter litres 3,75
Gearbox oil grade SAE 80W
Gearbox 4/5 speed litres 1,9
Automatic transmission fluid Type Dexron III
Cooling system litres 7,0
Brake fluid Type DOT 3/4
Brake fluid litres 0,5
Power steering fluid Type Dexron II/III
Power steering fluid litres 1,0
