It is the throttle body pulley that keeps swinging when the machine is running,and i can feel the same on the gas pedal when the car is slowing down .i did scan for the third time and it always indicates that the problem is in the cable that is attached to the throttle.
Should I fix or replace the whole throttle or replace the whole cable?
What is the minimum length cable required to complete the procedure?
thanks
