SA,
In the Yaris F/O Automatic, How to know if the ABS is working or not?
Thanks in advance
SA,
Thanks in advance
@120 km/hr
Push the brakes pedal hard
Stay pushing
Steer left & right
Feel the vibrations in the brakes pedal
Thanks
Eng.Sherif Shaker
Thanks
Is there any light indicator beside the speedometers
like the one for the handbreak
easily when you turn on your contact
there's a light indicator for ABS stays for about 3 seconds
you can also try yourself to feel it at the minimum speed you can drive,
just push the brakes firmly , you going to feel repeatitive pulses on brakes pedals
"there's a light indicator for ABS stays for about 3 seconds"
I have the F/O Automatic and there's no any light indicators :(
how to turn it ON :(
روح فى حتة فيها شوية رمله على الأرض او مياة و بعدين امشى بسرعة معقولة و بعدين فرمل مرة واحدة بكل قوتك لو لاقيت Vibration تحت رجلك فى الدواسة يبقى ال ABS تمام
جربت على الأسفلت
لقيت حاجة بتفك و تمسك تامى بسرعة
كأنها كلابشات بتمسك الكاوتش و تسيبه و تمسكه بسرعة
قلت كفايه لحسن أخلص ال Abs و أروح املاه تانى :d
