عربيه تقول الهامر يا توك توك ...
عربيه تقول الهامر يا توك توك ... :)
انتاج كندا
اسمها Knight XV
http://dc01.arabsh.com/i/00406/s3x6skiphjs5.bmp
http://auto.cheb.ru/forum/uploads/po...249405805.jpeg
من الداخل شقه اوضه و صاله بمنافعهم :
http://www.4wdmonthly.com.au/flashne...%20XV%2006.jpg
http://www.blogcdn.com/www.autoblog....ight_kv_av.jpg
عجله القياده ..
دي المواصفات الفنيه للي بيفكر يشتريها :
سعرها $295,000
Length 240" (6096 mm)
Width 98" (2489 mm)
Ground clearance 14" (355 mm)
Height 100" (2540 mm)
The KNIGHT XV is built on a Ford F350 commercial platform chassis (making parts easily accessible globally)
Engine: 6.8L V10 gas power plant with E-85 Ethanol Conversion system - Flex Fuel with California emission (making it certified in all 50 US States). Flexible fuel vehicles (FFVs) are designed to run on gasoline or a blend of up to 85% ethanol (E85).
Horsepower: 400 HP and torque 498 ft lbs.
4 X 4: Four wheel drive with locking hubs 4.30 ratio limited slip differential transmission: 5-speed automatic
Brakes: Four-wheel disc anti-lock brakes
Wheelbase: 141" (3576 mm)
GVWR: 13,000lbs (5,896 kg)
Armoured Curb Weight: The finished vehicle weight is approximately 10,000 lbs. (4,545 kg)
Fuel tank: 40 gallons (US) (151Litres)
Air conditioning: Factory Air conditioning
Tires: Four LT40X13.50R20 Mickey Thompson Baja Radial ATZ with ballistic run flats
Vehicle armour: The armour specifications as well as the levels of armour are available upon request.
http://www.otakku.com/wp-......./upl...ight_xv_02.jpg
