جربته يا باشا قعد شوية و بعدين كتب تم المسح لكن فى الحقيقة مفيش حاجة اتمسحت
و شكرا
الموضوع ممكن يكون Security Permissions لو البارتيشن عندم NTFS ممكن تقوم بالتالي:
- انقر باليمين على المجلد المطلوب إزالته واختر Properties واختر "Security"
- انقر زرار Advanced في الثلث الأخير من الشاشة الظاهرة
- في الشاشة التي ستظهر قم بالتعليم Check على الاختيار الأول "Inherit form parent the permission entries ....." ثم نقر OK
غالباً سيكون بإمكانك حذف المجلد بعد هذه الخطوة لو مانفعش ياريت قول لي وإن شاء الله فيه حلول تانية
طيب مارضيش يعني لما غيرت الـ Permissions قال Access is denied؟ وللا التغيير تم بس مارضيش يمسح الملف؟
فيه برنامج اسمه Unlocker
و ده اللينك للتحميل
Unlocker Download - Softpedia
[justify]Get rid of error message like Error deleting file or folder, cannot delete folder: it's being used by another person or program
Unlocker application was designed to be a very useful Windows Explorer extension allowing users with a simple right-click on a file or folder to easily get rid of error message such as error deleting file or folder, cannot delete folder: it's being used currently.
Helps delete locked files with error messages like:
· Cannot delete file: Access is denied
· There has been a sharing violation.
· The source or destination file may be in use.
· The file is in use by another program or user.
· Make sure the disk is not full or write-protected and that the file is not currently in use.
Note: Some antivirus and antispyware programs flag Unlocker as being infected/malware, although the application is perfectly safe and does not pose a threat to your system. This is called a 'false positive'. The term false positive is used when antivirus software wrongly classifies an innocuous ( inoffensive ) file as a virus. The incorrect detection may be due to heuristics or to an incorrect virus signature in a database. [Similar problems can occur with antitrojan or antispyware software.]
[/justify]
يبقى ممكن نمشي بالعكس .. نروح على الدرايف نفسه ومن شاشة الـ security -> Advanced ونختار Replace Permission entries on all child objects بس ده هاياخد شوية وقت وبعدين نحاول الحذف.
طب شوف ده كده
LockHunter is a free 64/32 bit tool to delete files blocked by any processes
Supports both 32 and 64bit Windows OS: Windows 2000, XP, 2003, Vista, 7
[warning]At the moment LockHunter is in beta stage. So use it with care![/warning]
