كارت شاشة msi 128 up to 256 mb مع البوردة
مواصفات الكارت
MSI RX300HM-TD128ELF
ATi Radeon X300SE 128MB DDR Supports Hypermemory to 256MB PCI Express (PCIe) Video Card with DVI, VGA, TV-Out, DirectX 9: MS-V032-01S (Retail, Powered by ATi) (Discontinued)
VDPEMIRX3SE1http://ep.yimg.com/ca/Img/trans_1x1.gif$45.99http://ep.yimg.com/ca/Img/trans_1x1.gif
* Enhanced Power Lead for PCI-Express Video Cards: None1x 6Pin Shielded Clean Power Lead for PCI-Express /CBPCXPVGAP6P/ (+14.99) Quantity:
MSI RX300HM-TD128ELF ATi Radeon X300SE 128MB DDR Supports Hypermemory to 256MB PCI Express (PCIe) Video Card with DVI, VGA, TV-Out, DirectX 9: MS-V032-01S (Retail, Powered by ATi)
RADEON™ X300 Features
- SMARTSHADER™ 2.0
- SMARTSHADER™ defines the level of realism in latest 2D/3D games and applications
- Complete hardware-accelerated Microsoft® DirectX® 9.0 programmable vertex and pixel shader support
- Full hardware support for OpenGL® 2.0
- SMOOTHVISION™ 2.1
- SMARTSHADERM™ improves image quality by smoothing jagged edges, improving blurriness and refining background details during on-screen motion and at lower resolutions
- SMOOTHVISION™ settings are user configurable in ATI CATALYST™ Control Panel:
- 2x/4x/6x Anti-Aliasing (AA) modes
- Sparse multi-sample algorithm with gamma correction, programmable sample patterns and entroid sampling
- Loss-less Color Compression (up to 6:1) at all resolutions
- 2x/4x/8x/16x Anisotropic Filtering (AF) modes
- Up to 128-tap ....ure filtering
- Adaptive algorithm with bilinear (performance) and trilinear (quality) options.
- HYPER Z™ III
- HYPER Z™ ensures optimal hardware performance bydiscarding irrelevant object data that is not visible to end-user on their display.
- Leverages key features from ATi's third generation HYPER Z™ III technology that conserves video memory bandwidth for improved performance in demanding 2D/3D games and applications
- Lossless Z-Buffer Compression (up to 48:1)
- Fast Z-Buffer Clear
- Z Cache optimized for real-time shadow rendering
- VIDEOSHADER™
- Seamless integration of pixel shaders with video in real time
- FULLSTREAM™ video de-blocking technology for Real, DivX, and WMV9 formats
- VIDEOSOAP™ noise removal filtering for captured video
- MPEG 1/2/4 decode and encode acceleration
- DXVA Support
- Hardware Motion Compensation, iDCT, DCT and color space conversion
- Adaptive Per-Pixel De-Interlacing and Frame Rate Conversion (temporal filtering)
- ADDITIONAL FEATURES
- Dual integrated display controllers
- Dual integrated 10 bit per channel 400 MAz DACs
- Integrated 165 MHz TMDS transmitter (DVI 1.0 / HDMI compliant and HDCP ready)
- Windows® Logo Program compliant
- ATI CATALYST™ Software Suite
Product Specification2D Display Modes
- Resolutions, colors and maximum refresh rates(Hz) in 256, 65K, 16.7M colors
- 640 x 480: 200Hz
- 800 x 600: 200Hz
- 1024 x 768: 200Hz
- 1152 x 864: 200Hz
- 1280 x 1024: 160Hz
- 1600 x 1200: 120Hz
- 1920 x 1080: 120Hz
- 1920 x 1200: 100Hz
- 1920 x 1440: 90Hz
- 2048 x 1536: 85Hz
Warranty1 Year ManufacturerPlease Note: This is a PCI-Express Video Card and it requires a Motherboard equipped with a PCI-Express X16 SlotBundle Software
- MSI Live Update Series ( Live VGA BIOS & Live VGA Driver)
- Automatically online download & update VGA BIOS & Drivers, reduce the risk of getting the wrong files, and never have the trouble on ... site searching.
- 3D! Turbo Experience
- Fancy, Game-looking HTML/Flash Based Tool
- New revolution! MSI is the worldwide first company to propose the advantage of HTML/Flash based utilities. By leading the new software trend, MSI devotes to serve the users a fancy, game- looking utility. Are you ready for the new experience now?
- GoodMen
- Automatically release the system memory space, reduce the risk of system hang-up.
- LockBox
- Instantly enter the data lock mode when you must leave your system for a while.
- WMIinfor
- Automatically list the detail system configuration, it helpful for engineering service people.
- ThinSoft BeTwin
- MSI Secure DOC
- E-Color
- Adobe Acrobat Reader
- Trend Micro PC-Cillin 2000
- Microsoft® DirectX 8.1
System Requirement
- Operating Systems Support Windows® XP / 2000
السعر 100 جنية
لاتصال 0101521626
pci-express
