Chevrolet Corvette ZR1 - 2008
The ZR1's basic stats:
All-new LS9 supercharged 6.2L V-8 targeted at producing at least 100 horsepower per liter, or 620 horsepower (462 kW), and approximately 595 lb.-ft. of torque (823 Nm)
Six-speed, close-ratio, race-hardened manual transmission
New, high-capacity dual-disc clutch
Higher-capacity and specific-diameter axle half-shafts; enhanced torque tube
Specific suspension tuning provides more than 1g cornering grip
Twenty-spoke 19-inch front and 20-inch rear wheels
Michelin Pilot Sport 2 tires - P285/30ZR19 in front and P335/25ZR20 in the rear - developed specifically for the ZR1
Standard carbon-ceramic, drilled disc brake rotors - 15.5-inch-diameter (394-mm) in the front and 15-inch-diameter (380-mm) in the rear
Larger brake calipers with substantially increased pad area
Standard Magnetic Selective Ride Control with track-level suspension
Wider, carbon-fiber front fenders with ZR1-specific dual vents
Carbon-fiber hood with a raised, polycarbonate window - offering a view of the intercooler below it
Carbon-fiber roof panel, roof bow, front fascia splitter and rocker moldings with clear-coated, exposed carbon-fiber weave
ZR1-specific full-width rear spoiler with raised outboard sections
Specific gauge cluster with boost gauge (also displayed on the head-up display) and 220-mph (370 km/h) speedometer readout
Only two options: chrome wheels and a "luxury" package
Curb weight of approximately 3,350 pounds (1,519 kg)
