يعني عنوان الخبر بيقول
The Japanese automaker says the problem from 2007 is not the same problem involved in the Jan. 21 recall
سيبت انت ده وجبت العنوان
Auto industry sources: Toyota knew of pedal problem in 2007
أول جزء في الخبر
Toyota, however, said Saturday that the potential problem with the accelerator pedal in vehicles subject to the ongoing callback differs from a problem discovered in 2007 that caused sudden acceleration.
و اللينك التاني برضه مصدره
(The Detroit News) اللي عملنا بحث فيها و مالقيناش الخبر
وبفرض ان الخبر ده كان موجود الرد بتاعهم إن دي مشكله تانية غير اللي بتستدعي استعادة السيارات اليومين دول
مشكلة 2007 كانت
TOYOTA IS RECALLING CERTAIN MODEL YEAR 2004-2010 PASSENGER VEHICLES. THE ACCELERATOR PEDAL CAN GET STUCK IN THE WIDE OPEN POSITION DUE TO ITS BEING TRAPPED BY AN UNSECURED OR INCOMPATIBLE DRIVER'S FLOOR MAT
وده من اللينك اللي انت جايبها
2007 Lexus ES350 Recalls, Defects, Recall Reports & Problems at InternetAutoGuide.com
لكن المشكلة الحالية ممكن تفهمها شوية من الفيديوهات دي
Toyota Recall Videos – Electronic Throttle Control Video
Toyota Recall Videos – Floor Mat Entrapment Video
Toyota Recall Videos – Accelerator Pedal Assembly Video
من موقع تويوتا
The first recall, "Floor Mat Entrapment," regards the potential for an unsecured or incompatible driver's floor mat to interfere with the accelerator pedal and cause it to get stuck in the wide-open position.
The second recall, "Pedal," is being conducted because there is a possibility that certain accelerator pedal mechanisms may mechanically stick in a partially depressed position or return slowly to the idle position.
