المشاركة الأصلية كتبت بواسطة MMamdouh
Lanos: front upgrade is a must... rear upgrade is optional
Nubira: rear upgrade to disks is a nice upgrade
most important is the pads type... those should be matched to driving style... if you are a hard braker use a hard compound pads like the Turkish Besher or so... but note that those pads won't perform untill they are hot
if you use brakes gently use Gold or Genuine pads... if you don't ever get excited while driving and never go to high speeds then you should use the Japanese pads (can't remember the name right now)
