Citroen DS High Rider concept تجمع بين محرك ديزل ومحرك كهربائى
اصدرت سيتروين الصور الاولى للسيارة سيتروين DS هاى رايدر
والتى سيكشف النقاب عنها فى معرض جينيف الثمانين للمحركات
والسيارة عبارةعن دمج بين سمات تصميمى الكوبيه والدفع الرباعى
ولم تكشف حتى الآن عن الصور الداخلية للسيارة
وتعتمد السيارة فى حصولها على الطاقة على محرك ديزل يعمل جنبا الى جنب مع
محرك كهربائى يقع على المحور الخلفى
وهى بهذا تجمع بين كفاءة الوقود والطاقة من محرك ديزل وبين الفوائد البيئية للسيارة الكهربائية
Citroën has released the first images of the DS High Rider concept set to be unveiled at the 80th Geneva Motor Show. The second concept associated with Citroën's new DS line, the compact crossover blends the design attributes of a coupe and a compact SUV.
Measuring just 4260mm long, 1820mm wide and 1480mm high, the compact crossover has a muscular aesthetic, expressed by a high waistline and a gently sloping roof line that is coated with a ....ile material. At the front, gaping air intakes, long incisive headlights and defined ridges along the hood give the vehicle a dynamic DRG. Citroen has yet to provide images of the interior, but the French automaker claims it 'provides occupants with a generous amount of internal space'.
_
_
_
[youtube]http://www.youtube.com/watch?v=GfJDRUoPld8[/youtube]
_
_
_
The DS High rider sources power from a diesel engine working in conjunction with an electric motor located on the rear axle. The hybrid platform enables the concept to combine the fuel efficiency and power of a diesel engine with the ecological benefits of an electric car. Under certain conditions, both engines combine to deliver increased power with additional torque transmitted to the rear wheels
