دي خطوات المحافظة على البطارية من موقع HP
- Store Li-Ion batteries between 20°C and 25°C (68°F and 77°F) with 30% to 50% charge.
- Do not disassemble, crush, or puncture a battery; do not short the external contacts on a battery; and, do not dispose of a battery in fire or water.
- Do not leave batteries exposed to high temperatures for extended periods. Prolonged exposure to heat (for example, inside a hot car) accelerates the deterioration of Li-Ion cells.
- Remove the battery if the notebook will be stored (turned off and not plugged into AC power) for more than 2 weeks.
- Remove the battery from the notebook if the notebook will be plugged into AC power continuously (via a wall adapter or docking station) for more than 2 weeks.
- Use the type of battery with the highest capacity (Ah) rating if the notebook will run high-end applications on battery power.
- Calibrate the battery based on the usage model. Under normal usage, batteries should be calibrated a minimum of once every 3 months; however, a battery that is rarely discharged fully should be calibrated about once a month
- Keep the battery away from children.
- Use only the battery provided with the computer, a replacement battery provided by HP, or a compatible battery purchased as an accessory.
النقطة دي مش فاهمها ,, ممكن توضيح ؟؟
كتر خيركم على المعلومات الجميلة دى ..
بس خلونا نركز فى نقطة واحدة ..
حد حاطط اللاب توب أغلب الوقت فى البيت ، وطبعاً بيشتغل على الكهرباء ..
ازاى يتعامل مع البطارية بطريقة تحافظ عليها؟
هل يشيلها واللا يخليها
ولو شالها ، تكون مشحونة أد ايه ، ويركبها كل أد ايه ..
ولو خلاها ، هل يفضل من وقت لآخر انه يشتغل بيها واللا يخليه يعتمد على كهرباءالمنزل؟
Content Relevant URLs by
vBSEO 3.6.0 PL2
