علي فكرة كلام احد سامي صحيح - انا قريت الكتالوج تاني ولقيت انة كالاتي
For your safety, the automatic transaxle
has a shift lock system which prevents
shifting the transaxle out of P (Park)
unless the brake pedal is depressed.
To shift the transaxle from P (Park) into R
(Reverse):
1. Depress and hold the brake pedal.
2. Start the engine or turn the ignition
switch to the ON position.
3. Move the shift lever.
If the brake pedal is repeatedly
depressed and released with the shift
lever in the P (Park) position, a chattering
noise near the shift lever may be heard.
This is a normal condition
Shift-lock overridethe brake, then do the following:
If the shift lever cannot be moved from
the P (Park) or N (Neutral) position into
the R (Reverse) position with the brake
pedal depressed, continue depressing
Type A1. Carefully remove the cap covering the
shift-lock access hole (1).
2. Insert a key (or screwdriver) into the
access hole and press down on the
key (or screwdriver).
4. Have your vehicle inspected by an
authorized KIA dealer immediately.Type B1. Press the shift-lock release button.authorized KIA dealer immediately
2. Move the shift lever.
3. Have your vehicle inspected by an
