النتائج 1 إلى 8 من 8
    الصورة الرمزية hegazyhany
    رقم العضوية : 14843
    السيارة: Lancer 98
    السيارة[2]: Opel Vectra C
    الحالة : hegazyhany غير متواجد حالياً
    افتراضي شكوى من فيكترا c و التوكيل (عيب صناعه) - Facebook Twitter whatsapp انشر الموضوع فى :
    اعضاء العصابه الاعزاء - هام جدا
    اثناء البحث على الانترنت تم العثور على هذه الشكوى من احد ملاك الفيكترا فى مصر على الرابط التالى.
    Opel Vectra Complaints - Fatal Failure
    لو حد عنده فكره - رجاء المشاركه لافاده الجميع - و كيف لم نسمع به من قبل.
    [justify]
    Dear sir,
    The attached photos refer to a fatal failure that happened to my car and could have ended with a catastrophy if not for God mercy.
    My car is an OPEL VECTRA that I bought from your representative in Egypt - Mansour- in Novemenber 2007 and only run for 29000KM, the car is still under Warranty.
    While driving on a highway in March 23rd I suddenly couldn't press the break pedal as it turned into stone!!
    I Luckily managed to stop the car using both engine and hand breaks till it stopped on the sideway. I drove the car very slowly to the nearest gaz station, where I found that the Servo Valve controlling the break system broke as per the attached photos!!!
    I precisely refer to the top flat part( the outlet), the other end was still embeded into the input hose. I called your emergency help center and I allocated the nearest service center at Nasr City. After 2 hours of very slow manouvers I reached the service center. the technical engineers at Mansour confirmed that they have never seen such a failure and had no explaination for it!!!
    the attached photos show the broken part - that I had to pay for it by the way- as they refused to admit the this type of failures is covered by the warranty.
    the photos show clearly the flat part that was broken, the nozzle remained in the hose. the irregular bottom nozzle showed in the middle picture was broken during the process of extraction from the bottom hose as per their say.
    My life is not cheap to be treated with such shallowness. Your car could have ended my life.
    I request serious investigation and expect a phone call from a reliable personnel
    [/justify]
    الصورة الرمزية asd7778
    رقم العضوية : 32576
    السيارة: لا يوجد
    السيارة[2]: Opel insignia 2014
    دراجة بخارية: uiojolji
    الحالة : asd7778 غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة hegazyhany مشاهدة المشاركة
    opel vectra complaints - fatal failure
    [justify]
    dear sir,
    the attached photos refer to a fatal failure that happened to my car and could have ended with a catastrophy if not for god mercy.
    My car is an opel vectra that i bought from your representative in egypt - mansour- in novemenber 2007 and only run for 29000km, the car is still under warranty.
    While driving on a highway in march 23rd i suddenly couldn't press the break pedal as it turned into stone!!
    I luckily managed to stop the car using both engine and hand breaks till it stopped on the sideway. I drove the car very slowly to the nearest gaz station, where i found that the servo valve controlling the break system broke as per the attached photos!!!
    I precisely refer to the top flat part( the outlet), the other end was still embeded into the input hose. I called your emergency help center and i allocated the nearest service center at nasr city. After 2 hours of very slow manouvers i reached the service center. The technical engineers at mansour confirmed that they have never seen such a failure and had no explaination for it!!!
    The attached photos show the broken part - that i had to pay for it by the way- as they refused to admit the this type of failures is covered by the warranty.
    The photos show clearly the flat part that was broken, the nozzle remained in the hose. The irregular bottom nozzle showed in the middle picture was broken during the process of extraction from the bottom hose as per their say.
    [/justify]
    انا قرأته فعلا قبل كدا
    بس الموضوع ده فردى وواضح ان القطعة الى عنده كان فيها عيب صناعة
    لان اموضوع ده ما حصلش مع حد قبل كدا
    والله اعلم
    الصورة الرمزية N.a.j.d
    رقم العضوية : 35093
    الاقامة : JorDan egypt
    السيارة: Corsa 2007 1.4
    السيارة[2]: Astra 2003 2.0
    الحالة : N.a.j.d غير متواجد حالياً
    غريبه المشكله دي
    بس طالما عربيه من عند منصور يبقى عيب توكيل وليس صناعه
    soon 2011
    [img3]http://img103.herosh.com/2010/03/17/929079106.jpg[/img3]
    لا اله الا الله محمد رسول الله
    الصورة الرمزية shifu
    رقم العضوية : 52329
    السيارة: mowasalat
    السيارة[2]: motoregl
    الحالة : shifu غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة N.a.j.d مشاهدة المشاركة
    غريبه المشكله دي
    how can it be dealer problem from the letter above it is car problem
    if the guy said that he had fixed the car and then 2 days later this happened we could have said dealer problem but he did not say that
    الصورة الرمزية tananybasha
    رقم العضوية : 23085
    الاقامة : Giza
    السيارة: لايوجد حالياً
    السيارة[2]: Opel Vectra A Sport 2.0L M/T
    دراجة بخارية: هوندا 1000
    الحالة : tananybasha غير متواجد حالياً
    نفس العيب حصل عندى بس بعد عمر افتراضى 14 سنه
    لو أن ابن آدم هرب من رزقه كما يهرب من الموت لأدركه رزقه كما يدركه الموت
    محمد الطنانى
    الصورة الرمزية tamertamer
    رقم العضوية : 26835
    الاقامة : القاهرة (مصر الجديدة)
    السيارة: HONDA CBR 919RR
    السيارة[2]: Opel Vectra B
    دراجة بخارية: honda
    الحالة : tamertamer غير متواجد حالياً
    دية مشكلة فردية لا تنتبق على الفكترا عموما دة شىء فردى
    i love my car
    رقم العضوية : 23085
    الاقامة : Giza
    عيب فردى و جديد
    محمد الطنانى
    رقم العضوية : 35093
    يعني المشكله دي محصلتش مع حد ابل كدا يبقى عيب فردي
    soon 2011
  1. مشاركات: 607
    آخر مشاركة: 07-09-2011, 05:59 AM
  2. شكوى من التوكيل
    بواسطة tornado_5m في المنتدى بــروتـــون
    آخر مشاركة: 12-07-2010, 08:11 PM
  3. إلى كل من عنده شكوى من التوكيل، من فضلك شارك بشكواك
    بواسطة sa7aby في المنتدى هـــــــوندا
    مشاركات: 16
    آخر مشاركة: 07-07-2010, 01:04 AM
  4. شكرا لتوكيل بروتون .... مكالمة متابعة من التوكيل بدون شكوى
    بواسطة islamnabil في المنتدى بــروتـــون
    مشاركات: 12
    آخر مشاركة: 21-05-2010, 07:14 PM
  5. مشاركات: 4
    آخر مشاركة: 18-01-2010, 05:44 PM
00, 000, 000km, 007, 07, 18, 185, 20, 200, 2007, 23, 29, 290, 33, 34, 3rd, 53, 85, 90, 900, 9000, ملاك, ab, abl, action, لاعز, لان, ad, لبحث, لتوكيل, af, aft, لى, لجميع, al, allo, ana, ans, مش, مشارك, مشاركه, مصر, app, art, asr, ast, مع, لعصابه, لفيكترا, az, من, break, broken, c1, ام, المشارك, المشاركه, الاعزاء, الانتر, الانترنت, الت, التالى, البحث, التو, التوكيل, الجميع, call, الرابط, الشكوى, car, الع, العصا, العصابه, الفيكتر, الفيكترا, center, ابه, اثنا, اثناء, cheap, city, ck, cl, clear, ار, complaint, complaints, confirmed, contro, control, cover, اعز, اعضاء, اف, افاده, انت, انتر, انترنت, da, de, dear, dr, driving, du, تم, egypt, el, eli, ely, eng, engin, engine, engineer, engineers, enter, er, es, ev, explain, extra, به, توكيل, fa, failure, failures, fat, fe, fi, fo, ft, fy, gen, gi, gin, god, hand, hap, happen, hed, hey, high, highway, hot, hour, html, http, hwa, جميع, ide, جدا, il, ir, iv, يف, ده, ken, km, la, le, led, left, li, life, ll, low, lp, luc, luck, main, man, mansour, mb, men, merge, mid, middle, mp, na, nas, nasr, nat, رابط, nf, ng, رجاء, nov, ره, رن, سمع, صا, شار, شارك, od, opel, ot, صناع, صناعه, شكوى, part, pay, pen, person, phone, photo, photos, pic, picture, pla, pp, pre, pro, pt, put, ra, rc, reach, red, reg, request, rest, ring, rio, rm, roll, rom, rr, rs, run, se, sel, serious, serv, service, servo, shallow, show, si, side, sir, size, sl, slow, slowly, sr, ss, st, station, sti, stig, stop, sudden, sys, system, tast, te, tech, technical, tha, ti, till, tone, top, tp, trac, traction, trophy, tt, turn, type, على, uc, عدة, عز, عصا, عزاء, عصابه, ur, عه, عن, عند, عنده, عضاء, valve, vectra, vi, vin, wa, war, warranty, xp, xt, فا, فاده, في, فيك, فيكتر, فيكترا, فك, فكر, فكره, ها, هام, هام جدا, هذ, هذه, نا, ور, نسمع, وكيل, ضا, قبل, كت, كتر, كي, كيل, كيف, كره
عرض سحابة الكلمة الدلالية
