I would like your advice on a car between Lancer 1.3 Automatic or the Ibiza 1.4 Automatic also from the point of stability witch one is better or if you recommend another car in the same range witch is 100
لانسر ده رايي
انا رأى ابيزا
لأن الانسر 1300 أتوماتيك أدئها مش كويس
لو1600 يبأى الانس أكيد
Thank you for you answer but i would like you to tell why did you choose the lancer
Ibiza but not automatic
The problem is I don’t like manual driving I prefer if the car is automatic; the only satiation that I will get the manual in is if I get the VW Cross fox, and that is because I like the quality of the German cars over the Japanese cars.
