المشاركة الأصلية كتبت بواسطة SHNORY
اسف علي التاخير
اتفضل يا باشا
MEP2(Network): 6961169661262360
ودي الطريقه
Unlock instructions:
1. Insert SIM card
2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0)
3. Select "Advanced options" or "Advanced system settings" -> "SIM Card"
4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard
5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4)
NOTE: You will not see any .... appear on the screen while typing on step 3 and 4.
6. You should be presented with a prompt "Enter Network MEP Code"
7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm
8. Device is now unlocked.
NOTE: Make sure you follow these or the instructions correctly.
If you enter the unlock code incorrectly ten times, the device will permanently lock to the carrier to which it is branded.
