اقتباس:
المشاركة الأصلية كتبت بواسطة samirayad
وأعمل أيدل ليرن بطريقه صح كما هو موصوف للدايو
Turn the ignition ON for 5 seconds.
Turn the ignition OFF for 5 seconds.
Start the engine in park/neutral.
Allow the engine to run until the engine coolant is above 185° F (85°C ).
Turn the A/C ON for 10 seconds, if equipped.
Turn the A/C OFF for 10 seconds, if equipped.
If the vehicle is equipped with an automatic transaxle, apply the parking brake. While pressing the brake pedal, place the transaxle in D (drive).
Turn the ignition OFF. The idle learn procedure is complete.
