صفحة 4 من 4 الأولىالأولى 1 2 3 4
النتائج 31 إلى 38 من 38
  1. #31
    الصورة الرمزية zizo50001
    رقم العضوية : 10479
    الاقامة : مدينة العبور-القاهرة
    السيارة: Opel Astra G 1.6
    السيارة[2]: Opel Vectra b2 2.0 136 hp
    الحالة : zizo50001 غير متواجد حالياً
    ياريت يا جماعة حد يعمل فينا خدمة و يترجم
    "يَا أَيُّهَا الَّذِينَ آمَنُوا إِن جَاءكُمْ فَاسِقٌ بِنَبَأٍ فَتَبَيَّنُوا أَن تُصِيبُوا قَوْماً بِجَهَالَةٍ فَتُصْبِحُوا عَلَى مَا فَعَلْتُمْ نَادِمِينَ"صدق الله العظيم
  2. #32
    الصورة الرمزية elkarsh
    رقم العضوية : 46185
    الحالة : elkarsh غير متواجد حالياً
    بصو يا جماعه انا ترجمت دا عن طريق جوجل بس مش ترجمة مظبوطة مي
    ... Images Videos Maps News Shopping Gmail more Groups Books Scholar Finance Blogs
    YouTube Calendar Photos ........s Reader Sites
    even more »
    <IMG height=1 alt="" width=1><IMG height=1 alt="" width=1>Home.... and ...Translated SearchTools
    Translate ...., ...page, or ........
    Enter .... or a ...page URL, or upload a .........
    Translation: English » Arabicby Pete Evans This How To explains how to repair your TID display once it has shown signs of fatigue by loosing parts of the display as shown below. As you can see, it's impossible to see the clock or outside temp, and the date/radio station is corrupted. Tools needed:For dash removal - Flat screwdriver, Crosshead screwdriver (magnetic if possible), 4 feeler gauges (I used normal kitchen knives)For digi repair - Small flat screwdriver, Soldering Iron, De soldering tool/wick (not essential), Stanley Knife, Old Toothbrush, Cable tie.First, you must remove the dashboard clocks. It sounds daunting, but it really is quite easy. The only fiddly bits are the vents really. I couldn't unscrew my steering wheel height adjuster, so I had to leave the bottom column shroud on, but that didn't matter. I must stress that you SHOULD NOT turn on the ignition with the dash out, this will trigger an airbag sensor fault which can only be reset by Vauxhall.Once the clocks are removed unscrew the two securing scres for the TID. This will allow the remove of the Digital unit and you should end up with this..To gain access to the module, you need to cut the "anti-tamper" lugs which are moulded into the sides do this with a Stanley knife.Now the back should come off and the internals should appear like thisThe next step is to de-solder the 3 contacts for the clock setting buttons. This is easier if you have a de soldering tool (RS part no 544-516) or some de soldering wick, obtainable from any electronics shop like Tandy etc.Once the contacts have been de soldered, you can remove the assembly like shown above.Now the only things holding the module in its casing are the retaining clips. Press these in and carefully draw the module out. This is what it looks like above.Mine is the simple "Triple Info Display (TID)" but the multifunction ones are similar. They have 1 long ribbon instead of 4 small ones.Here's where it gets a little bit tricky. Don't worry - it's buggered anyway so what have you got to lose ? Carefully begin to peel the ribbon away from the circuit board - NOT FROM THE LCD !!. Gently pull it downwards like this. Stop pulling once you ahve about 2mm of the contacts showing.Now using a Stanley knife blade, scrape off the grey carbonised deposits which will have oxidised onto the circuit board connector. Be careful, we don't want to totally scrape off the gold contact, just the dusty white/grey stuff. Here's a picky of before cleaning/after cleaning.Don't be tempted to jump to the next contact until the one you're working on is clean. It's totally boring I know, but you might as well do it properly now you've got the thing in bits. Try and scrape along the length of the contact rather than across it. This is to reduce the chance of a short circuit. When you are happy the contacts are nice and clean, give them a gentle rub with an old toothbrush to remove any debris.Now it's time to put the thing back together. In addition to the "heated joint" method, Siemens have used a silicon band to apply extra pressure to the joint. We need to apply even more pressure to ensure a decent connection, so find something that will sit nicely underneath the silicon band, and is about 1 - 2 mm thick. I wouldn't recommend something that conducts electricity as this could short out the clock setting buttons when you replace the contacts. I used an 8" cable tie cut down to size like this....Hold each contact up with a small screwy while you solder.Now carefully replace the back part of the outer cover, clicking it's locking tabs into position. Remember there will be a little more tension due to the thickness of the cable tie sitting on the circuit board/ribbon cable joint. Now it's just a case of refitting to to your dash, then fitting that into the car.
    من بيت ايفانز
    هذا ما يفسر كيف لكيفية إصلاح جهاز العرض الدار مرة واحدة إلا أنها لم تبد علامات التعب من فقدان أجزاء من العرض كما هو مبين أدناه. كما ترون ، أنه من المستحيل أن نرى على مدار الساعة ، أو درجة الحرارة في الخارج ، والتاريخ / محطة إذاعية معطوب.
    الأدوات اللازمة :
    لإزالة اندفاعة -- مفك مسطح ، Crosshead مفك (المغناطيسي إذا كان ذلك ممكنا) ، 4 المحسس مقاييس (أنا استخدمت سكاكين المطبخ العادية)
    ياكون للإصلاح -- مفك شقة صغيرة ، لحام الحديد ، دي أداة لحام / الفتيل (ليس ضروريا) ، ستانلي السكين ، قديم فرشاة الأسنان ، كبل التعادل.
    أولا ، يجب إزالة الساعات لوحة أجهزة القياس. الامر يبدو صعبا ، ولكن في الواقع هو في غاية السهولة. بت فقط ذكي هي المخارج حقا. أنا لا يمكن أن انفك بلدي المقود ارتفاع المكيف ، لذلك اضطررت لمغادرة أسفل العمود في كفن ، ولكن هذا لا يهم. ولا بد أن أؤكد أنه لا ينبغي عليك تشغيل الإشعال مع الخروج سريعا ، وهذا يؤدي الى وسادة هوائية استشعار الخطأ الذي لا يمكن إلا أن تكون إعادة تعيين من قبل فوكسهول.
    مرة واحدة في الساعات تتم إزالة انفك اثنين scres لتأمين الدار. وهذا سيسمح لإزالة وحدة رقمية ويجب في نهاية المطاف مع هذا..
    للوصول إلى وحدة ، كنت في حاجة لخفض "مكافحة التلاعب" العروات التي تشكلت في الجانبين القيام بذلك بسكين ستانلي.
    الآن يجب أن يعود للخروج من الملعب والأجزاء الداخلية يجب أن يظهر مثل هذا
    والخطوة التالية هي دي جندى للاتصالات على مدار الساعة 3 لتحديد الأزرار. هذا هو أسهل إذا كان لديك أداة دي لحام (جمهورية صربسكا جزء لا 544-516) أو بعض الفتيل دي لحام ، يمكن الحصول عليها من أي متجر للادوات الالكترونية مثل تاندي الخ.
    مرة واحدة والاتصالات قد تم دي ملحوم ، يمكنك إزالة مثل التجمع هو مبين أعلاه.
    الآن لشيء سوى عقد وحدة في غلاف هي مشابك. الصحافة في هذه بعناية ولفت إلى وحدة نمطية. هذا هو ما يبدو أعلاه.
    الألغام هي بسيطة "تريبل عرض المعلومات (الدار)" ولكن تلك متعدد الوظائف هي مشابهة. لديهم 1 الشريط الطويل بدلا من 4 صغيرة.
    هنا المكان الذي تحصل عليه قليلا خادعة. لا تقلق -- انه متعب على أي حال حتى ما عندك لتخسره؟ تبدأ بعناية لقشر الشريط بعيدا عن لوحة الدارات -- ليس من شاشات الكريستال السائل!. اسحبها إلى أسفل من هذا القبيل. وقف سحب مرة واحدة لديك حول 2mm للاتصالات تظهر.
    الآن باستخدام نصل السكين ستانلي ، وكشط ودائع الرمادية متفحمة والتي سيكون لها كيديسيد على لوحة الدارات الرابط. كن حذرا ، ونحن لا نريد أن تتخلص تماما قبالة الاتصال الذهب ، فقط بيضاء المتربة / الاشياء رمادية. وهنا لإرضاءه من قبل التنظيف / بعد التنظيف.
    لا يميل إلى القفز على اتصال واحدة المقبل حتى إذا كنت تعمل على نظيف. انها مملة وأنا أعلم تماما ، ولكن قد كنت كذلك نفعل ذلك بشكل سليم الآن كنت قد حصلت على شيء في بت. حاول وكشط على طول للاتصال عبر بدلا من ذلك. هذا هو لتقليل فرصة حدوث ماس كهربائي. عندما كنت سعيدا للاتصالات هي جميلة ونظيفة ، ومنحهم فرك لطيف مع فرشاة الأسنان القديمة لإزالة أي حطام.
    الآن حان الوقت لوضع الشيء معا مرة أخرى. بالإضافة إلى "مشتركة حامية" الأسلوب ، سيمنز استخدمت الفرقة السيليكون لممارسة ضغوط اضافية للمشترك. نحن بحاجة لتطبيق المزيد من الضغط لضمان وجود اتصال لائق ، لذلك تجد شيئا جيدا سوف نجلس تحتها الفرقة السيليكون ، وحوالي 1 -- 2 مم. أنا لا أوصي بأن شيئا ما يوصل الكهرباء لأن هذا يمكن أن قصيرة من الزمن وضع أزرار عند استبدال الاتصالات. أنا استخدم 8 "الكابل التعادل خفض لحجم مثل هذا...
    تعقد كل اتصال حتى مع مجنون الصغيرة بينما كنت جندى.
    الآن بعناية الاستعاضة عن الجزء الخلفي من الغطاء الخارجي ، والنقر انها قفل التبويبات في موضعه. تذكر انه سيكون هناك مزيد من التوتر قليلا نظرا لسمك الكابل التعادل يجلس على لوحة الدارات / كبل شريط مشترك. الآن انها مجرد حالة تجديدها لاندفاعة إلى حسابك ، ثم من المناسب أن داخل السيارة.
    English—Detect language—AfrikaansAlbanianArabicBelarusianBulgar ianCatalanChineseCroatianCzechDanishDutchEnglishEs tonianFilipinoFinnishFrenchGalicianGermanGreekHebr ewHindiHungarianIcelandicIndonesianIrishItalianJap aneseKoreanLatvianLithuanianMacedonianMalayMaltese NorwegianPersianPolishPortugueseRomanianRussianSer bianSlovakSlovenianSpanishSwahiliSwedishThaiTurkis hUkrainianVietnameseWelshYiddish > Arabic—AfrikaansAlbanianArabicBelarusianBulgaria nCatalanChinese (Simplified)Chinese (Traditional)CroatianCzechDanishDutchEnglishEstoni anFilipinoFinnishFrenchGalicianGermanGreekHebrewHi ndiHungarianIcelandicIndonesianIrishItalianJapanes eKoreanLatvianLithuanianMacedonianMalayMalteseNorw egianPersianPolishPortugueseRomanianRussianSerbian SlovakSlovenianSpanishSwahiliSwedishThaiTurkishUkr ainianVietnameseWelshYiddish swap
    Contribute a better translationThank you for contributing your translation suggestion to Google Translate.
    We'll use your suggestion to improve translation quality in future updates to our system.<BR><BR>من بيت ايفانز <BR><BR>هذا ما يفسر كيف لكيفية إصلاح جهاز العرض الدار مرة واحدة إلا أنها لم تبد علامات التعب من فقدان أجزاء من العرض كما هو مبين أدناه. كما ترون ، أنه من المستحيل أن نرى على مدار الساعة ، أو درجة الحرارة في الخارج ، والتاريخ / محطة إذاعية معطوب. <BR>&nbsp; الأدوات اللازمة : <BR>لإزالة اندفاعة -- مفك مسطح ، Crosshead مفك (المغناطيسي إذا كان ذلك ممكنا) ، 4 المحسس مقاييس (أنا استخدمت سكاكين المطبخ العادية) <BR>ياكون للإصلاح -- مفك شقة صغيرة ، لحام الحديد ، دي أداة لحام / الفتيل (ليس ضروريا) ، ستانلي السكين ، قديم فرشاة الأسنان ، كبل التعادل. <BR>أولا ، يجب إزالة الساعات لوحة أجهزة القياس. الامر يبدو صعبا ، ولكن في الواقع هو في غاية السهولة. بت فقط ذكي هي المخارج حقا. أنا لا يمكن أن انفك بلدي المقود ارتفاع المكيف ، لذلك اضطررت لمغادرة أسفل العمود في كفن ، ولكن هذا لا يهم. ولا بد أن أؤكد أنه لا ينبغي عليك تشغيل الإشعال مع الخروج سريعا ، وهذا يؤدي الى وسادة هوائية استشعار الخطأ الذي لا يمكن إلا أن تكون إعادة تعيين من قبل فوكسهول. <BR><BR>مرة واحدة في الساعات تتم إزالة انفك اثنين scres لتأمين الدار. وهذا سيسمح لإزالة وحدة رقمية ويجب في نهاية المطاف مع هذا.. <BR><BR>للوصول إلى وحدة ، كنت في حاجة لخفض "مكافحة التلاعب" العروات التي تشكلت في الجانبين القيام بذلك بسكين ستانلي. <BR><BR>الآن يجب أن يعود للخروج من الملعب والأجزاء الداخلية يجب أن يظهر مثل هذا <BR><BR>والخطوة التالية هي دي جندى للاتصالات على مدار الساعة 3 لتحديد الأزرار. هذا هو أسهل إذا كان لديك أداة دي لحام (جمهورية صربسكا جزء لا 544-516) أو بعض الفتيل دي لحام ، يمكن الحصول عليها من أي متجر للادوات الالكترونية مثل تاندي الخ. <BR>مرة واحدة والاتصالات قد تم دي ملحوم ، يمكنك إزالة مثل التجمع هو مبين أعلاه. <BR><BR>الآن لشيء سوى عقد وحدة في غلاف هي مشابك. الصحافة في هذه بعناية ولفت إلى وحدة نمطية. هذا هو ما يبدو أعلاه. <BR><BR>الألغام هي بسيطة "تريبل عرض المعلومات (الدار)" ولكن تلك متعدد الوظائف هي مشابهة. لديهم 1 الشريط الطويل بدلا من 4 صغيرة. <BR>هنا المكان الذي تحصل عليه قليلا خادعة. لا تقلق -- انه متعب على أي حال حتى ما عندك لتخسره؟ تبدأ بعناية لقشر الشريط بعيدا عن لوحة الدارات -- ليس من شاشات الكريستال السائل!. اسحبها إلى أسفل من هذا القبيل. وقف سحب مرة واحدة لديك حول 2mm للاتصالات تظهر. <BR><BR>الآن باستخدام نصل السكين ستانلي ، وكشط ودائع الرمادية متفحمة والتي سيكون لها كيديسيد على لوحة الدارات الرابط. كن حذرا ، ونحن لا نريد أن تتخلص تماما قبالة الاتصال الذهب ، فقط بيضاء المتربة / الاشياء رمادية. وهنا لإرضاءه من قبل التنظيف / بعد التنظيف. <BR><BR>لا يميل إلى القفز على اتصال واحدة المقبل حتى إذا كنت تعمل على نظيف. انها مملة وأنا أعلم تماما ، ولكن قد كنت كذلك نفعل ذلك بشكل سليم الآن كنت قد حصلت على شيء في بت. حاول وكشط على طول للاتصال عبر بدلا من ذلك. هذا هو لتقليل فرصة حدوث ماس كهربائي. عندما كنت سعيدا للاتصالات هي جميلة ونظيفة ، ومنحهم فرك لطيف مع فرشاة الأسنان القديمة لإزالة أي حطام. <BR><BR>الآن حان الوقت لوضع الشيء معا مرة أخرى. بالإضافة إلى "مشتركة حامية" الأسلوب ، سيمنز استخدمت الفرقة السيليكون لممارسة ضغوط اضافية للمشترك. نحن بحاجة لتطبيق المزيد من الضغط لضمان وجود اتصال لائق ، لذلك تجد شيئا جيدا سوف نجلس تحتها الفرقة السيليكون ، وحوالي 1 -- 2 مم. أنا لا أوصي بأن شيئا ما يوصل الكهرباء لأن هذا يمكن أن قصيرة من الزمن وضع أزرار عند استبدال الاتصالات. أنا استخدم 8 "الكابل التعادل خفض لحجم مثل هذا... <BR><BR>تعقد كل اتصال حتى مع مجنون الصغيرة بينما كنت جندى. <BR>الآن بعناية الاستعاضة عن الجزء الخلفي من الغطاء الخارجي ، والنقر انها قفل التبويبات في موضعه. تذكر انه سيكون هناك مزيد من التوتر قليلا نظرا لسمك الكابل التعادل يجلس على لوحة الدارات / كبل شريط مشترك. الآن انها مجرد حالة تجديدها لاندفاعة إلى حسابك ، ثم من المناسب أن داخل السيارة.<BR><BR><BR>Google Home - About Google Translate Beta
    ©2009 Google
    ه في المية ممكن تقربكم شوية للموضوع
    moha2
  3. #33
    الصورة الرمزية mark2
    رقم العضوية : 9023
    الاقامة : المنيا
    السيارة: اوبل
    السيارة[2]: بيجو
    الحالة : mark2 غير متواجد حالياً
    ارجو ان تكون مترجمة عربى و لك جزييييييل الشكر
  4. #34
    رقم العضوية : 9023
    الاقامة : المنيا
    السيارة: اوبل
    السيارة[2]: بيجو
    ارجو ان تكون طريقة الاصلاح بالعربى و شكرا
  5. #35
    الصورة الرمزية tananybasha
    رقم العضوية : 23085
    الاقامة : Giza
    السيارة: لايوجد حالياً
    السيارة[2]: Opel Vectra A Sport 2.0L M/T
    دراجة بخارية: هوندا 1000
    الحالة : tananybasha غير متواجد حالياً
    صعب قوى تلاقيها بالعربى
    لو أن ابن آدم هرب من رزقه كما يهرب من الموت لأدركه رزقه كما يدركه الموت
    محمد الطنانى
  6. #36
    الصورة الرمزية hostook
    رقم العضوية : 46245
    الاقامة : egypt
    السيارة: دايو لانوس موديل 99 1500 سي سي
    السيارة[2]: اوبل كورسا 1600 موديل 2004 سيدان
    الحالة : hostook غير متواجد حالياً
    والهي تمام بس هل نفس الطريقة في شاشة اوبل كورسا 2004
  7. #37
    الصورة الرمزية ghost
    رقم العضوية : 6651
    الاقامة : مدينة 6 اكتوبر
    السيارة: هيونداى اكسنت1995
    السيارة[2]: بولنيز1993
    الحالة : ghost غير متواجد حالياً
    شكرا يا برنس
    هو ده الكلام
    Mr Ghost
  8. #38
    الصورة الرمزية mostafa4443
    رقم العضوية : 173079
    الاقامة : المنصورة
    السيارة: اوبل فيكترا 97
    السيارة[2]: اوبل فيكترا 97
    الحالة : mostafa4443 غير متواجد حالياً
    بصراحة اعضاء ممتازين ومنتدى اكثر من ممتاز ... وانا تابعت الموضوع بدقة ونفذت وعرفت افك العدادات وشاشة البيانات وده توفيق من الله اولا ثم الفضل للمنتدى والأعضاء ... وللعلم شاشة البيانات ( فيشة صفراء ) عند عبوده في سمنود حوالة 100 جنيه .. وكمان عرفت افك الفرش السقف بعد متابعة تعليمات الأعضاء واشتريت واحد تانى من عبودة 550 جنيه - سألت عليه في بنك الإسكان ببورسعيد كان 750 جنيه .. واشتريت من عبوده مراية كهرباء 250 جنيه ..... بجد شكرا للمنتدى الغالي بمعلومات الأعضاء الممتازين
  1. اصلاح شاشة المعلومات من فضلكم
    بواسطة عاصم حسنين في المنتدى أوبـــــل
    مشاركات: 28
    آخر مشاركة: 04-12-2012, 01:49 AM
  2. اصلاح شاشة المعلومات فى الفيكترا بى
    بواسطة عاصم حسنين في المنتدى مشاكل الكهربــاء
    آخر مشاركة: 12-11-2012, 12:31 AM
  3. شاشة المعلومات
    بواسطة abousaef1996 في المنتدى أوبـــــل
    مشاركات: 14
    آخر مشاركة: 09-11-2011, 11:18 PM
  4. شوفت شاشة المعلومات دى
    بواسطة lancerevolution في المنتدى أوبـــــل
    مشاركات: 17
    آخر مشاركة: 11-06-2010, 12:19 PM
  5. شاشة المعلومات
    بواسطة honda forever في المنتدى أوبـــــل
    مشاركات: 19
    آخر مشاركة: 13-09-2009, 09:28 PM
