النتائج 1 إلى 4 من 4
    الصورة الرمزية Mohamedkhadr
    رقم العضوية : 69274
    السيارة: بروتون واجا
    السيارة[2]: iهيونداى اكسيل
    الحالة : Mohamedkhadr غير متواجد حالياً
    افتراضي اسعار قطع غيارالواجا الجديدة فى ماليزية للعلم - Facebook Twitter whatsapp انشر الموضوع فى :
    FOB (RM) Headlamp Bosch Original (per Side) 278.00 TailLamp Bosch Original (per Side) 105.00 FogLamp Bosch Original ( per side) 195.00 Waja Local door handle- r piece 11.00 Waja coloured door handle- according to ur original colour-r 28.00 Waja Side Mirror- Local per side 168.00 Exedy clutch kit set for Waja 1.6- 248.00 Brake Pad. Bendix ....l King Titanium (front), (rear) F 98.00 R 92.00 Brake Pad. Mintex from UK. front R 58.00 R 58.00 ProtonBrake Pad- front Bosch ( 1 pair) 45.00 FBKBrake Pad- rear Bosch ( 1 pair) 45.00 FBKWaja Window regulator-....l one front 128.00 local back 158.00 Waja original proton power window motor- front, rear per side 48.00 Taiwan (TW)Waja Timing belt Gates- (full warranty 178.00 PowerTiming Belt Dayco(Europe) 60.00 belt onlyBosch timing belt kiot set - complete setBosch timing belt kit - complete setAdd air-con, fan belt dayco 28.00 BandoWaja 1.6 top overhaul set Original Proton (many fakes out there) 188.00 SOWAWaja 1.6 overhaul set Original Proton (many fakes out there) 238.00 SOWAWaja 1.6 front wheel bearings (per side)SKF Brand + oil seal 65.00 NTNrear wheel bearings (per side) 135.00 Waja 1.6 throttle body- Original ProtonWaja 1.6 fuel pump Original Proton 380.00 Waja 1.6 brake master pump proton edar selling TW 98.00 210.00 Waja 1.6 brake booster Original Proton 430.00 Waja 1.6 steering (with 2 buttons complete) Original Proton Waja 1.6 power window switch main 98.00 Waja 1.6 wiper switch 158.00 Waja 1.6 wiper motor-Original Proton 210.00 Engine mounting 1.6 (auto/manual) total 4cps.. Original proton F/R 58.00 LH/RH 135.00 Waja 1.6 front & rear bumper Original Proton per sideAPM coil spring normal size-front rear per side F 65.00 R 55.00 TWWaja 1.6 original driveshaft whole batang per side Ori 298.00 TW 178.00 Waja 1.6 bonnet Original Proton (grey)-, add nose Ori 330.00 TW 220.00 Waja 1.6 fender/mudguard front Original Proton per side (grey) Ori 110.00 TW 76.00 Waja fender cover/protector local- per piece Ori 75.00 TW 45.00 Waja 1.6 Bumper Bracket- front local 95.00 TWWaja 1.6 front Bumper Original Proton Ori 160.00 TW 80.00 Waja 1.6 rear Bumper Original Proton- Ori 160.00 TW 80.00 Waja 1.6 rear sensor Original Proton 55.00 Kayaba absobers front (gas), rear (gas) per side F 135.00 70.00 Waja absorber mountings Original Proton local per side 80.00 Waja absorber link Original Proton per side 68.00 Waja Central Lock front per side, back per side Original Proton F 190.00 R 170.00 Waja window glass rubber per side 45.00 Waja Glove Box Handle 52Proton, rm26 localWaja Air-con Blower- please let me know Denso/ Patco--Waja Bosch wiperblade- 30.00 Waja H1 Osram-Waja 1.6 Bosch air filter Waja 1.6 bosch fuel filter Waja GMB water pump-Bosch Super 4 FR78X per box, Bosch Platinum Plus for 4 pcs,Bardahl oil treatment,1 can- Bosch Dot4 Brake Fluid 1 litre-Proton original ATF fluid 1 litre- per litreFuchs SP111 ATF fluild 1 litre-- German brandFuchs gear oil 80/90
    ملحوظة الاسعار ده غير شاملة الشحن والجمرك يعنى ممكن اضافة 30%كمان
    والاسعار برنمبت الماليزى يساوى حوالى 1.73جنيه مصرى
    شكرا
    محمد خضر
    الصورة الرمزية pedro732000
    رقم العضوية : 36867
    الاقامة : suez
    السيارة: واحد كفاية
    السيارة[2]: Persona 2010 manual F.O
    الحالة : pedro732000 غير متواجد حالياً
    ممكن لو سيدتك تجبلينا معاك اسعار قطع غيار البيؤسونا والجين 2 لو سمحت
    يارب سترك ورضاك عنا
    الصورة الرمزية Tarek Gen 2
    رقم العضوية : 65708
    الاقامة : agoza + 6 october
    السيارة: Kia Cerato 2010 Ex Red
    السيارة[2]: Gen 2 2010 Blue
    الحالة : Tarek Gen 2 غير متواجد حالياً
    موضوع محتاج تنظيم عن كدة
    و مشكور جدااا لمجهودك
    الصورة الرمزية ahmed_h_g
    رقم العضوية : 8588
    الاقامة : Ras Ghareb/Red Sea
    السيارة: 000
    السيارة[2]: Proton wira 2005
    الحالة : ahmed_h_g غير متواجد حالياً
    شكرا عالأفاده
    مينفعش الموضوع كان يتنظم أكتر من كده ؟
  1. اسعار الساوند الجديدة
    بواسطة Loay94 في المنتدى قســـم الصوتـــيات
    مشاركات: 19
    آخر مشاركة: 29-11-2012, 11:48 PM
  2. اسعار السيارات الجديدة
    بواسطة body_ss في المنتدى بيـــع و شــــراء
    آخر مشاركة: 17-02-2010, 10:54 AM
  3. (منقول) نصائح ماليزية لمالكى سيارات بروتون
    بواسطة ghareeb في المنتدى بــروتـــون
    مشاركات: 6
    آخر مشاركة: 20-01-2010, 07:30 PM
  4. للعلم فقط (و ربما للحسرة ايضا) اسعار السيارات 2008 بالسعودية
    بواسطة الريس في المنتدى المنتــــــدى العـــــــــــام للسيــارات
    مشاركات: 25
    آخر مشاركة: 09-08-2008, 05:40 PM
