تركيب زينون
http://www.forteforums.com/forums/im.../wol_error.gif
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060666.jpg
Test fitting all the connections and plugged everything in the car.
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060667.jpg
I used a 1” hole saw and made a hole onto the cover as shown
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060670.jpg
I ran the wires through and used black caulking on the grommet to help seal the grommet once in-place
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060671.jpg
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060672.jpg
I added a few strips of double sided tape and adhered the ballasts to the top of the windshield washer reservoir and the body as shown.
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060673.jpg
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060677.jpg
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060678.jpg
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060718.jpg
The lighting is incredible. The cut-off is actually quite low for a headlamp assembly that’s not designed for HID lighting output.
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060669.jpg
تركيب كلكس قوى
Hella Supertone horn set install
After driving the Koup for a week, I found that it was necessary to this little car a louder bark. There are too many driver’s that obviously forgot or don’t care looking before changing lanes.
Youtube was a great source when it came to being able to listen to a variety of aftermarket horns.
I liked the Hella Supertone’s the best so I was on a quest to find them locally which I did.
I purchased them from a cool place called NextMod ( www.nextmod.com ).
The owner Peter is a great guy.
Just a word of caution, you can get carried away in his shop with all the available goodies....don’t say I didn’t warn you!
Before video: original single horn
http://i916.photobucket.com/albums/a...h_P1060777.jpg
After video: Hella Supertone’s behind bumper
http://i916.photobucket.com/albums/a...h_P1060819.jpg
Instructions: I used the 2b wiring diagram with the relay. Some say it isn’t necessary to hook up the relay, but I did anyways to be safe. I also used a 20amp fuse.
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...structions.jpg
Here are some installation pictures;
Begin by using some low-tack painters tape around the headlamp assembly to avoid any potential damage due to the headlamp removal.
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060780.jpg
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060782.jpg
remove this little puppy!
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060783.jpg
I found this to be a suitable location which is just inboard of the fog lamps and away from any direct water impact that would potentially reduce the life of the production finish
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060784.jpg
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060785.jpg
I drilled a hole that will accept an M6 collapsible riv nut
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060786.jpg
M6 collapsible Riv nut installed
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060790.jpg
horn mounted
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060791.jpg
both horns mounted
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060792.jpg
I ran the original connector back through the opening and tied it just under the headlamp area
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060793.jpg
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060794.jpg
these are some pictures of pre-wiring and checking for proper function before I add in all the connectors and wire loom
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060796.jpg
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060797.jpg
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060798.jpg
here is everything all connected along with all the wires in a wire loom
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060799.jpg
Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060800.jpg
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060801.jpg
Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060804.jpg
I used a lot of cable tied in case you haven’t noticed yet. The wires are running along the top of the radiator support for the right side of the car and back down.
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060806.jpg
This image has been resized. Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060807.jpg
Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060809.jpg
Click this bar to view the full image.http://i916.photobucket.com/albums/a...0/P1060810.jpg
Part details:
Hella Supertone Horn Set
2x 66W
500 Hz (high tone)
300 Hz (low tone)
118dB (A)
Relay included
3AG 003 399-801 (12V)
حلو قوي الكلام ده
بس ليه بيفك كل حاجة حتة حتة
مثلا مفيش داعي للفك ده كلو لتركيب الكلاكس
أو حتى الزنون انا ركبتو و زي اللي في الصور بس من غير ما فك النور كلو عشان هتتغير عيارات النور.
بس تفتح الغطا و تحفرو و تركب الزينون بكل بساطة و تثبت المحول جنب النور مش تحتو شكل الراجل ده هواية بالفك
تحياتي..
This image has been resized. Click this bar to view the full image.http://i926.photobucket.com/albums/a...up-SX-R-_1.jpg
On your Koup at this angle it looks like the chin sits lower than the sides. Maybe I'm wrong and it's just the angle the shot was taken.
This image has been resized. Click this bar to view the full image.http://i926.photobucket.com/albums/a...3/P1070189.jpg
Content Relevant URLs by
vBSEO 3.6.0 PL2
