النتائج 1 إلى 10 من 11
الموضوع: Mercedes-benz Cls Detailing
    الصورة الرمزية PRO-DRIVE
    رقم العضوية : 63
    الاقامة : Dystopia , blashyrkh
    السيارة: N/A
    السيارة[2]: Subaru Impreza 2006
    الحالة : PRO-DRIVE غير متواجد حالياً
    افتراضي Mercedes-benz Cls Detailing - Facebook Twitter whatsapp انشر الموضوع فى :
    انا اليومين دول منبهر اوي بموضوع البولش و الواكس
    دي تجربه واحد في انجلترا اصبروا بس علي الصور
    شوافوا قبل و بعد بجد النتيجه مبهره جدااااااااااااااااا
    I got to my car, and it still wasnt light yet, oh how we love this time of year.
    see told you it was still dark -flash this time
    First job was the wheels. Sprayed with de-greaser and rinsed, as were arches, shuts and jams. I then cleaned the alloys, and moved on to the bodywork:
    Once all clean, clayed with SV paint rubber and dried I moved the car inside and checked Paint Depth Readings and applied the 3m 3434 masking tape.
    A quick look round at the paintwork:
    and decision made to test in on the boot panel:
    I continued on the flat surfaces, moving to the roof and then the bonnet. You will notice the deeper RDS's are not being taken out. The decision was made to not remove that much clear coat, as the owners cat will continue to use the cat as an evening bed.
    into the side panels, the upper shoulder has been machined here:
    and some shots as I worked down the nearside:
    and a reverse on the opposite wing:
    After the machining I then applied Swissvax Cleaner Fluid Pro. This was also applied to door shuts and the alloys.
    The customer had chosen to have Swissvax Saphir wax. So this was applied to the paintwork and door shuts. Swissvax Autobahm was applied to the alloys, and metal polish to the exhaust. All exterior trim, arches and tyres were dressed with Swissvax Pneu.
    Inside, leather was cleaned with Swissvax Leather Cleaner, and then The Leather Milk applied. All hard surfaces cleaned, and the drivers mat was done with the extractor. I cleaned all glass with Swissvax Crystal and then applied the Seal Feed to the rubber door seals.
    Am so glad I was inside, not the nicest of days outdoors. Needless to say, indoor after pics only:
    thank you for reading
    الموضوع انا حاططه في العام عشان اسأل
    هو الواكس و البولش دول نجيبهم منين في مصر :(
    طيب المكنه اللي بتلف دي بتاعت الواكس كنت قريت عندهم انها عادي رخيصه في منها
    اجهزه صغيره بتتباع حد يعرف فين برضه ؟؟
    انا اساسا بصدد تصليح الخبطه اللي عندي بس برضه لسه مش عارف فين :D
    بس اكييييد بعد ما اصلحها علطوووول حعمل حاجه كدا في العربيه :D
    <!--EndFragment-->
    الصورة الرمزية mmido32
    رقم العضوية : 3901
    السيارة: lesa
    السيارة[2]: 132
    الحالة : mmido32 غير متواجد حالياً
    شكرا على الصور. بس هوه الwax بيتحط علي الازاز برده ولا اللمعه اللي فيه من ايه؟
    الصورة الرمزية Ahmed Anwer
    رقم العضوية : 794
    السيارة: هيونداي فيرنا أوتوماتيك 2007
    السيارة[2]: رينو فلوينس
    الحالة : Ahmed Anwer غير متواجد حالياً
    تسلم ايديك موضوع جميل ،،،
    بانتظار بقية المعلومات من الأخوة
    الصورة الرمزية Chicco
    رقم العضوية : 1375
    الحالة : Chicco غير متواجد حالياً
    بصراحة العربية تستاهل كل خير :)
    الصورة الرمزية memo_hefnawy
    رقم العضوية : 1
    الاقامة : Nasr City
    السيارة: ----
    السيارة[2]: ---
    دراجة بخارية: ....*
    الحالة : memo_hefnawy غير متواجد حالياً
    بص يا عم أحمد صباح الفل الأول :
    شوف الواكس موجود منه أنواع هنا فى مصر بس مش النوع إللى الراجل ده إتكلم عنه :) أنا دورت على النت لقيت إن سعر النوه بتاعه ده داخله فى 600 جنيه و زيادة :) ههههههههه
    هنا فى تيرتل واكس و فورميولا واكس دوول أكثر نوعين منتشرين العلبه هنا بتعملها حوالى 35 أو 40 جنيه
    بس الراجل لمعلومات الناس لم يستخدم الواكس فى كل حاجة الواكس على الصاج بس - فيه كيت كامل هو تقريبا متكلم عنه للجلد و للنواكل و التابلوه و الزجاج كذا حاجة يعنى
    الماكنة إللى بتسأل عليها يا أحمد موجودة عند بتوع العدد فى شارع الجمهورية ده عباره عن صاروخ و بيركب عليه الفرشة بس طبعا مش أى صاروخ عشان لو جبت واحد قوى أو متوسط هايبهدل الدوكو مش هايلمعوه يعنى فى ليمت بس أنا مش فاكره عشان مافتيش
    الواكس تلاقيه فى أى ماركت فى محطات البنزين - و الصاروخ ممكن كمان تلاقيه فى قسم العدد فى كارفور أو سبينيس (مش متأكد) بس هو موجود عند بتوع العدد و شارع الجمهورية أقرب ليك و أرخص
    الخبطة إللى عندك فى العربية كلم كريم و هو هايظبطك
    http://www.nilemotors.com/images/Nile_Audi_Memo_2.gif
    Dont Exhaust UrSelf in Thinking...Just Do what U have 2 Do...God Will Never Forget & Never Neglect
    رقم العضوية : 1
    الاقامة : Nasr City
    السيارة: ----
    السيارة[2]: ---
    دراجة بخارية: ....*
    أحمد أنا فتحت السايت إللى إنت ناقل عنه الموضوع و مبدأيا السايت كله إعلان عن المنتج السويزفاكس :)
    فده يخليك تشكك نوعا ما فى النتائج + مش عارف مش قادر أصدق إن فيه واكس يطلع النتيجه دى أو حته أى حاجة غير الواكس :)
    الصورة الرمزية Nader
    رقم العضوية : 57
    الاقامة : مدينة نصر
    السيارة[2]: هيونداي فيرنا
    دراجة بخارية: -
    الحالة : Nader غير متواجد حالياً
    واللي عاوز يشتري الواكس ممكن يجيبة يوم المقابلة من كارفور لانة بيتباع هنلك.
    اما بالنسبة للزجاج فكفاية اوي علي شوية جلانس وهو هيبرق.
    لأي استفسار أو شكوى بخصوص الإدارة والإشراف والدعم الفني، يرجى المراسلة على:
    رقم العضوية : 63
    السيارة: N/A
    شكرا علي الردود :)
    طيب حيدوا نفس النتيجه ؟؟
    يس :)
    انا برضه توقعت كدا
    في كيت كامل اسمه zymol دا برضه عاجبني اوي :(
    بس من المستحيلات اني الاقيه هنا في مصر :(
    بس انا شايفه علي النت ب49 دولار
    بس موجود فيه كل حاجه من اول الشامبو بتاع البودي و البولش و الواكس و منظف الجلد
    كل حاجه موجوده فيه
    <!--EndFragment-->
    رقم العضوية : 1
    الاقامة : Nasr City
    السيارة: ----
    السيارة[2]: ---
    دراجة بخارية: ....*
    أيوا يا عم أحمد بس لما أشترى الواكس لوحده ب 68 إسترلينى يبقى كثيير أوى أوى يعنى 600 700 جنيه واكس :) ليه :) ده كده إفترى
    الواكس إللى هنا هايدى نتيجة لا تقارن بكلام الصوره ده نهائى لأنى مجربه
    بيديلك ملمس ناعم و أملس و جميل و لامع لكن إللى فى الصورة ده غير واقعى بالمرة على الأقل فى حدود علمى
    و الواكس فيه منه نوعين واحد سايل و واحد كريمى - و فيه بعد كده شامبو للغسيل و ما إلى ذلك بس هنا كل ده أسعاره فى المعقول لكن 50 دولا أو 68 إسترلينى ده مبالغ فيه بس هل فعلا يستاهل الفرق .... الله أعلم
    ممكن تشترى من على النت لو حابب :) أو حد من معارفك يبعتلك من بره :)
    الصورة الرمزية أبو عبدالله
    رقم العضوية : 97
    الاقامة : ManSOuRa
    السيارة: coRoLLa 06
    السيارة[2]: siRiOn 07
    دراجة بخارية: ان شاء الله
    الحالة : أبو عبدالله غير متواجد حالياً
    المكنه دي غير الصاروخ يا محمود
    المكنه دي موجوده في هايبر عبارة عن جهاز على اد الأيد بداخله ماتور وفي الخراج اسفنجه عريضه مضغوطة بيركب عليها نوعيه معينه من القماش بيجي مع المكنه علشان الواكس يتحط عليه وتشغلها وهيا كانت بــ 350 تقريبا
    ونوعها بلاك اند ديكر
    انا عارف ان الصنايعيه بيستخدموا الصاروخ وكلن دي مخصوصه لكده واكيد هتبقى انعم بالذات علشان الاسفنجه وطريقة ماسكتها غير الصاروخ
    عن أبي هريرة قال :
    قال رسول الله صلى الله عليه وسلم :
    إذا قال الرجل لأخيه :جزاك الله خيرا ، فقد أبلغ في الثناء
  1. New Mercedes-Benz F 700
    بواسطة Sharky في المنتدى مــــرسيدس
    مشاركات: 13
    آخر مشاركة: 03-07-2013, 06:21 PM
  2. Mercedes Benz CLS 350
    بواسطة Mody_Benz في المنتدى مــــرسيدس
    آخر مشاركة: 05-10-2010, 11:19 PM
  3. Mercedes-Benz SLS AMG
    بواسطة كابوس الليل في المنتدى مقــاطـع الفيــديـو و الكليبات و صـور للسيارات
    مشاركات: 10
    آخر مشاركة: 13-09-2009, 12:26 AM
  4. Mercedes Benz C63 AMG vs. BMW M3
    بواسطة MMamdouh في المنتدى مقــاطـع الفيــديـو و الكليبات و صـور للسيارات
    آخر مشاركة: 24-02-2008, 05:24 PM
  5. Mercedes Benz SCL 600
    بواسطة اسلام المصرى في المنتدى مقــاطـع الفيــديـو و الكليبات و صـور للسيارات
    مشاركات: 21
    آخر مشاركة: 17-11-2007, 12:01 PM
