المشاركة الأصلية كتبت بواسطة hantu
Proton’s dyno tests of the new Campro IAFM engine reveals power ratings of up to 98 horsepower is achievable, but Proton prefers to publish the power figures in brochures at 94 horses for some reason, perhaps for consistency sake as not all engines may be able to achieve the 98 horses figure.
New Proton Saga Launch and Test Drive Report http://images.paultan.org/images/Pro...aga_torque.jpg
Saga's HP as quoted is 94hp but the dyno test showed it can achive 98 hp.. yes that is on wheel not on engine alone... could you tell me the source that said any car's BHP quoted on brochure is actually refer to the test on engine only ? if saga hp's figured 98hp on dyno test so what do you think gen2's hp ? might be lower than quoted in its brochure??
regards.
wassalam.
Thank you Mr.hantu,, a critical comment , especially you attach the source ,
now the question must be reflected ,,, if campro iafm in dyno test reveals 98hp ,,,so what is the result from engine directly ?! ,, without doubt ,, amazing result ..
regards
