[flash=http://www.hondashadow.net/forum/]width=350 height=600[/flash]
رقم العضوية : 27285
الاقامة : الكرة الأرضية
السيارة: -Cabrice-LTZ
السيارة[2]: ِAlfa156 seles-جيب جراند شيروكي
[flash=http://hondashadowacetourer.yuku.com/forums/96/t/service-and-maintenance.html]width=650 height=400[/flash]
إِن يَنصُرْ.كُمُ اللَّـهُ فَلَا غَالِبَ لَكُمْ ۖ وَإِن يَخْذُلْكُمْ فَمَن ذَا الَّذِي يَنصُرُ.كُم مِّن بَعْدِهِ ۗ وَعَلَى اللَّـهِ فَلْيَتَوَكَّلِ الْمُؤْمِنُونَ ﴿160)
م/محمد
رقم العضوية : 27285
م/محمد
رقم العضوية : 27285
This is the Honda recommended maintenance schedule for the Shadow Spirit (nearest cousin to the T).
600 mi/1,000 km Scheduled Maintenance
Engine Idle Speed*: Inspect and clean, adjust, lubricate, or replace, if necessary.
Clutch System: Inspect and clean, adjust, lubricate, or replace, if necessary.
Engine Oil: Replace.
Engine Oil Filter: Replace.
Carburetor Synchronization*: Inspect and clean, adjust, lubricate, or replace, if necessary.
Brake System: Inspect and clean, adjust, lubricate, or replace, if necessary.
Nuts, Bolts, Fasteners*: Inspect and clean, adjust, lubricate, or replace, if necessary.
Steering Head Bearings....: Inspect and clean, adjust, lubricate, or replace, if necessary.
4,000 mi/6,400 km Scheduled Maintenance
Spark Plug: Inspect and clean, adjust, lubricate, or replace, if necessary.
Brake Fluid (See Note #5): Inspect and clean, adjust, lubricate, or replace, if necessary.
Crankcase Breather (See Note #3): Clean.
Battery: Inspect and clean, adjust, lubricate, or replace, if necessary.
Brake Shoe/Brake Pad Wear: Inspect and clean, adjust, lubricate, or replace, if necessary.
8,000 mi/12,800 km Scheduled Maintenance
Spark Plug: Replace.
Radiator Coolant (See Note #5): Inspect and clean, adjust, lubricate, or replace, if necessary.
Final Drive Oil: Inspect and clean, adjust, lubricate, or replace, if necessary.
Fuel Line*: Inspect and clean, adjust, lubricate, or replace, if necessary.
Throttle Operation*: Inspect and clean, adjust, lubricate, or replace, if necessary.
Carburetor Choke*: Inspect and clean, adjust, lubricate, or replace, if necessary.
Cooling System*: Inspect and clean, adjust, lubricate, or replace, if necessary.
Brake Light Switch*: Inspect and clean, adjust, lubricate, or replace, if necessary.
Headlight Aim*: Inspect and clean, adjust, lubricate, or replace, if necessary.
Side Stand: Inspect and clean, adjust, lubricate, or replace, if necessary.
Suspension*: Inspect and clean, adjust, lubricate, or replace, if necessary.
Wheels/Tires....: Inspect and clean, adjust, lubricate, or replace, if necessary.
12,000 mi/19,200 km Scheduled Maintenance
Brake Fluid (See Note #5): Replace.
Air Cleaner (See Note #2)*: Replace.
Evaporative Emission Control System (See Note #4)*: Inspect and clean, adjust, lubricate, or replace, if necessary.
16,000 mi/25,600 km Scheduled Maintenance
20,000 mi/32,000 km Scheduled Maintenance
24,000 mi/38,400 km Scheduled Maintenance
Radiator Coolant (See Note #5): Replace.
Final Drive Oil: Replace.
م/محمد
رقم العضوية : 63440
السيارة: toyota
السيارة[2]: mits.
دراجة بخارية: cbr 1000rr
على فكره يا otefa الاستيد في امريكا بيسموه شادو خصوصا الاستيد ال 600
بس مواقع حلوه الصراحه
رقم العضوية : 27285
تمام يا QaTaR تسلم علي المعلومة.........أنا حاولت اساعد بمعلومة عن الشادو لأني بيني وبينك متابع الريس أكتر بكتير......وأهي بذرة تدي فكرة مبدأية عن how to search for maintenance........للمهتمين بالشادو......شكرااا
م/محمد
