KSPEC Inner Brace Kit
Recommended for racing or street use.
Improve the body rigidity with the inner brace kit.
Instantly improves handling with the correct suspension setup.
Best part of this is easy bolt on installation.
Welding is required for the brackets.
For other vehicles, please e-mail us for availability.
The price includes a set, left and right.
....*Shipping & Handling Included....*
http://www.kspec.com/img/tuca/reinforce_fender.jpg
Duralumin Centerbar
It connects the bottom of seat belts.
It doesn't get in the way of passengers in the back seat.
Last strut point upgrade after the front and rear strutbars.
http://www.kspec.com/img/suspension/centerbar.jpg
◈ Easy replacement dual catback for Forte Sedan 1.6
◈ Full dual muffler offers sporty sound with Gamma engine.
◈ Great rear view look with twin dual tips.
◈ No welding is neccessary.
◈ ALWAYS FREE SHIPPING
http://www.kspec.com/img/kia/forte_dual.jpg
....l Brake Hose from Earl's England
Please choose correct application for your vehicle.
http://www.kspec.com/img/brake/earls_forte.jpg
حد يفهمنا الكلام ده معناه اه ها ده شرح لاجزاء التربو
الرجاء الخبراء فقط يردوا عيزين نفهم
Turbo kit? Is this legit?? This kit is retailing on ebay for $1500. From the picture and the de......ion, it seems like a complete kit...
(1) Hybrid Turbo Charger:
* .57 compressor wheel trim mapped for low & high boost setups
* Oil fitting gaskets & mounting studs included
* Capable of producing over 450 horsepower
* Wet float bearings & properly balanced
* 3" inlet diameter with a 2" outlet
* .50 A/R compressor housing
* .63 A/R turbine housing
* 1/8 NPT oil inlet
* T3/T4 hybrid
(1) Front Mount Intercooler:
* Large design cools down the turbocharged air efficiently
* Strong TIG welds will support high PSI levels
* Lightweight aluminum racing intercooler
* Extra thick core provides ample cooling
* 2.5" cold outlet & 2.5" hot inlet
* Less then 2% pressure drop
(1) Universal Intercooler Piping Kit:
* Lightweight yet strong aluminum piping
* May necessitate light modification to fit
* (16) stainless steel worm gear clamps
* (2) 2.5” 90 degree silicone couplers
* (6) 2.5” straight silicone couplers
* (2) 90 degree 2.5” bends
* (2) 60 degree 2.5” bends
* (2) 45 degree 2.5” bends
* (2) straight 2.5” pipes
(1) Turbo Oil Line Install Package:
* T fittings will fit almost any motor & still use factory oil pressure sending unit
* Necessary fittings and clamps for a complete installation
* 18 inch 5/8” high temperature 550psi oil return line
* Premium gaskets & hardware for the turbocharger
* 77 inch straight high strength oil feed line
* Strong "T" fitting to hook up to block
* Superior quality lasts a lifetime
* Retails for $229 in magazines
* High quality oil feed fittings
* High quality turbo oil drain
* Brand new turbo install kit
* 36 inch angle oil fee line
(1) Aluminum Battery Box Relocation Kit:
* Full aluminum construction
* Relocation cables, straps, hardware
* Frees up lots of engine bay room
* Better weight distribution for vehicle handling
(1) Boost Controller:
* Can be setup to adjust boost PSI on the fly
* Can be adjusted for any PSI level desired
* Control your boost with a precise click
* Includes complete install kit
* Anodized aluminum finish
* CNC machined design
(1) Blow Off Valve:
* Protects turbo by venting when shifting and/or reducing throttle
* Performance design produces a powerful & aggressive sound
* Quality design will not leak under high boost conditions
* Flanges installed at user discretion
(2) Slim Cooling Fan:
* Fan can be used to cool: A/C condenser, oil or transmission cooler, mounting on an intercooler to prevent heat soak, or cooling a a2w radiator
* Slim design provides excellent engine bay clearance
* Includes the mounting tabs for a easy zip tie install
* Reversible design can either pull or push air
* Versatility of a push/pull reversible fan
* Superior flow of a curved-blade design
* Creates additional aftermarket cooling
* 1.25" thick outside perimeter
* 2.50" thick inside perimeter
(1) Electronic Turbo Timer:
* Ensures a proper cool down for your turbocharged car every time
* Includes pigtail wiring and extra wiring for ease of installation
* Important to preventing premature turbo wear and failure
* Mounted inside the vehicle for on the fly adjustments
* Precisely calculates the cool down period for the motor
* Auto mode feature creates a hassle-free operation
* Increases turbocharger's operating lifespan
* Bright Easy to read LED Digital Display
* Failure to reduce the temperature of the turbo could result in "coking" of oil inside the turbo
* Coking is the baking of oil, turning it into a grimy substance
(1) Fuel Pressure Regulator:
* Great to setup fuel pressure for boosted engines
* Precision pressure gauge
* Fully adjustable
(1) Catch Can:
* Stops excess oil from blowing to the intake manifold
* Ensures better mileage & better performance
* Removes oil vapors from breather line
* Show like high quality polish
(1) Billet Aluminum High Flow Fuel Filter:
* CNC machined T6-6061 billet aluminum construction
* High flow capacity for demanding fuel systems
* Strong brackets for easy mounting
* High pressure fuel fittings
* Anodized show like finish
* Filter can be cleaned
* 6an sized fittings
* Removable filter
(1) 35mm Wastegate:
* Protect the turbo system from over boosting by venting surges
* Includes complete install kit featuring gaskets and flanges
* Strong construction provides years of reliable service
* 2 bolt flange style
(1) 10 Meters Heat Wrap:
* Heat powers the turbochargers turbine inlet. Keep the heat inside the exhaust pipes
* Heat kills the turbochargers compressor inlet. Keep the heat out of the cold piping.
* Control additional engine bay heat and prevent overheating.
* Keep intercooled air cooled.
* Made of very high temp fiberglass.
(1) Stainless Downpipe:
* 2.5" Inlet
* Waterjet cut 5 bolt flange.
* Mandrel bent stainless steel
* Beautiful TIG welds
(1) Radiator Hose Sleeving Kit:
* Stainless braiding makes rubber radiator hoses up to 5x stronger
* Makes engine bay look of show car quality
* Strong construction provides years of reliability
* Anodized ends for the authentic race like finish
(1) High Flow Intake Filter:
* Protect the turbo system from debris
* Instant HP adder
* Extreme high flow
* 3" inlet perfectly matching the turbocharger inlet
(1) High Flow Breather Cap:
* Extreme high flow
* Keeps crankcase ventilation clean for emissions
* Works in conjunction with the catch can to keep inside of turbo piping oil free
(1) Wastegate Positioning Adapter:
* Allows adjustability for wastegate placement.
* Laser cut flanges.
* Mandrel bent stainless steel.
(1) Wastegate Dump Tube:
* Allows wastegate exhaust gases to cleanly exit the engine bay.
(1) Coolant Sensor Bung
* Monitor the water temperature via this sensor relocation
* Easy solution to run aftermarket coolant sensor
* Provides more precise readings then the stock location
* Features 2 installation clamps for an easy add on
* 38mm ends fits most OEM coolant hoses
* Strong Aluminum construction
(1) Non-divided T3 Flange
* Water jet cut for precision flow
* Mild steel for easy welding to an adapter pipe or direct to stock manifold
(1) Turbo Ram Inlet
* Increases airflow into the turbo system
* Replaces the filter for track performance
* Acts as a Ram Air
* Ultra lightweight and strong aluminum
(1) A-pillar Gauge Pod
* Mounts or replaces the existing pillar panel
* Angles 3 gauges perfect to the driver
* Lightweight plastic, hollow backing for gauge wire tucking
* ....ured finish, for an OEM look
(1) Dash Gauge Pod
* Mounts on dash or center console
* Angles 2 gauges perfectly to the driver
* ....ured finish, for an OEM look.
(1) Tachometer w/ Shift Light
* 5" sized
* White face, back lit
* 11k RPM max
* Programmable shift light for perfect shifts
(1) Oil Pressure Gauge
* 0-100psi range
* Mounting hardware and wiring included.
(1) Water Temp Gauge
* Small, lightweight design for an easy install anywhere
(1) Oil Temperature Gauge
(1) Boost/Vacuum Gauge
* 30in/hg vacuum, 30psi boost pressure
(1) Volt Gauge
* White Face, back lit
* 8v to 16v range
Any feedback would be welcome. I know that if I pieced together a system myself it would run about that price... so, any thoughts? Is this system missing anything?
Content Relevant URLs by
vBSEO 3.6.0 PL2
