2007 Toyota Camry
the new 2007 Toyota Camry ,the 4th generation Toyota Camry.
The new Toyota Camry is available in three versions – the low end Toyota Camry 2.0E , the Toyota Camry 2.0G and the high end 2.4V . This is a slight increase over the current prices where the 2.0E, and the 2.4V .The 2.0G is a new addition to the Camry range, a higher spec version compared to the Camry 2.0E.
Looking at the Thai specs list, which is likely not too be too different from the one we’re going to get here, the 2.0 liter model gets a small power bump from 142 horsepower at 5,600rpm to 145 horsepower at 6,000rpm, but peak torque remains the same at 190Nm @ 4,000rpm. The new 2.0 liter model’s gearbox is a Super ECT 4-speed, similiar to the one in the previous one, with the same ratios as well so it must be the same unit.
As for the 2.4 liter model, power is now 165 horsepower at 6,000rpm, up from the previous range’s 150 horsepower at 5,600rpm. Torque is up from 218Nm between 3,800rpm to 4,200rpm - it’s now 224Nm at 4,000rpm. The 2.4 liter model has a new gearbox, instead of the previous 4-speed Super-ECT, the new 2.4 liter Camry gets a 5-speed automatic gearbox with Sequential Shift. 2 of the gears are overdrive gears, for better fuel economy during highway cruising.
There is a 3.5 liter V6 version overseas, but it doesn’t look like it will be introduced here any time due to unfavorable market conditions. So the Camry has no competitor to go against the small volume Honda Accord 3.0 V6 for the moment.
