النتائج 1 إلى 10 من 30
    الصورة الرمزية NoraMagdy
    رقم العضوية : 70369
    النوع : انثى
    الاقامة : مصر
    السيارة: BMW 318 A/T
    السيارة[2]: Opel Vectra 2.0 CD 2001 A/T
    الحالة : NoraMagdy غير متواجد حالياً
    افتراضي إختصارات الرموز الفنية للسيارات Abbreviation - Facebook Twitter whatsapp انشر الموضوع فى :
    كود:
    Bodywork: HBK: Hatchback FBK: Fastback LAN: Landaulette TT: Targa top SAL: Saloon (sedan) FHC: Fixed-head coupé DHC: Drop-head coupé (cabriolet; convertible) TOUR: Tourer RDSR: Roadster EST: Estate (station wagon; shooting brake) MPV: Multi-purpose vehicle LDV: Light delivery vehicle VAN: Van (panelvan) SUV: Sport-utility vehicle ORV: Off-road vehicle LIM: Limousine (limo) ESP: Electronic Stability Program
    كود:
    Valve gear: OHV: Overhead valves SOHC: Single overhead camshaft DOHC: Double overhead camshaft (per bank) SV: Side valves SL: Sleeve valves TS: Two stroke ROT: Wankel Rotary oise: Overhead inlet, side exhaust RV: Rotary valves
    كود:
    Chassis: FWD: Front wheel drive RWD: Rear wheel drive AWD: All wheel drive 4WD: Four wheel drive
    كود:
    Fuel system: Ai: Aisan Am: Amal Au: Autolite B&B: Ball & Ball Bi: Bing Ca: Carter De: Dell'Orto Fo: Ford Hi: Hitachi Ho: Holley Ji: Jikov Ke: Keihin Lu: Lucas Mi-So: Mikuni-Solex Mi: Mikuni Ni-St: Nikki-Stromberg Ni: Nikki R-R: Rolls-Royce Ro: Rochester Ru: Russian SU: SU So: Solex St: Stromberg We: Weber Ze: Zenith FI: Fuel Injection EFI: Electronic Fuel Injection SMPFI: Sequential Multi-Point Fuel Injection SFI: Sequential Fuel Injection MPFI: Multi-Point Fuel Injection DDI: Direct Diesel Injection GDI: Gasoline Direct Injection Ku: Kugelfischer Ku-Bo: Kugelfischer-Bosch Lu-Bo: Lucas-Bosch Ho PGMFi: Honda programmable fuel injection Ma-We: Marelli-Weber Ni-De: Nippon-Denso
    كود:
    Suspension: ARB: Anti-roll bar CS: Coil springs dD: de Dion axle DW: Double wishbones I: Independent LA: Live axle LowTrailLi: Lower trailing link LS: Leaf spring LW: Lower wishbone MS: Macpherson strut MultiLi: Multi-link PR: Panhard rod QE: Quarter-elliptic leaf springs RA: Radius arms SE: Semi-elliptic leaf springs STA: Semi-trailing arm STLi: Semi-trailing link SlPl: Sliding pillar SwAx: Swinging axle TA: Trailing arm TB: Torsion bar TL: Transverse leaf spring TrailLi: Trailing link TzLi: Trapezoidal link U&LW: Upper & lower wishbones U&LRA: Upper & lower radius arms UW: Upper wishbone W: Wishbone WL: Watt's linkage
    كود:
    Brakes: Ve: Ventilated Di: Disc (Disk) Dr: Drum S: Servo-assisted ABS: Anti-lock Braking System EBD: Electronic Brake Distribution
    كود:
    Transmission: A: Automatic M: Manual SA: semi-automatic WP: Wilson preselector CVT: Continuously variable transmission OD: Overdrive 2X: Dual Speed Transfer Box SM: Sequential Manual M-CVT: Manual function-Continuously Variable Transmission S: Sequential P: Preselect
    إذا أهانك شخص فاسكت لان السكوت ابلغ آيات الاحتقار
    الصورة الرمزية ahmedbasto
    رقم العضوية : 14035
    الاقامة : tanta
    السيارة: chevy aveo 2012 MT
    السيارة[2]: Lancer EX 2015
    الحالة : ahmedbasto غير متواجد حالياً
    يشرفنى انى أول واحد يرد شكرا على الموضوع الرائع
    مقابلة جديدة للطنطاوية
    http://www.nilemotors.net/Nile/259689-a.html
    الصورة الرمزية M.Zaher
    رقم العضوية : 53568
    الاقامة : KSA-Riyadh
    السيارة: Nubira II CDX
    السيارة[2]: New Accent 2011
    دراجة بخارية: N/A
    الحالة : M.Zaher غير متواجد حالياً
    شكرا على الموضوع الجميل
    الصورة الرمزية gadix
    رقم العضوية : 27940
    الاقامة : شارع خاتم المرسلين - الهرم
    السيارة: رينو لوجان 2011
    السيارة[2]: فيات 128 موديل 1981
    الحالة : gadix غير متواجد حالياً
    تسلم ايدك علي الموضوع الجميل
    [img3]http://img46.imageshack.us/img46/4245/1867717134copy.jpg[/img3]
    تحت رعاية
    أقوى جروب لحمايه المستهلك من السرقة
    <!-- google_ad_section_end -->
    <CENTER></CENTER>
    الصورة الرمزية Car's Sniper
    رقم العضوية : 11305
    الاقامة : الشرقية
    السيارة: m2adeha baltaga
    السيارة[2]: Nubira 1
    دراجة بخارية: نفسي اجربها
    الحالة : Car's Sniper غير متواجد حالياً
    شكرا على الموضوع الجميل دا....ياريت حد يشرحلنا السسبينشن دا بالذات لأن 99% منه مش فاهمه بغض النظر عن fuel system :D :D
    نص مخى شريحة الكترونية ونصه التانى ماتور عربية
    محمود حمودة...صيدلى عاشق للهندسة
    الصورة الرمزية thunder155
    رقم العضوية : 37607
    الاقامة : A.R.E
    السيارة: not yet
    السيارة[2]: fiat uno 93
    دراجة بخارية: none
    الحالة : thunder155 غير متواجد حالياً
    شكراً على الشرح الوافى
    الصورة الرمزية Gabrial
    رقم العضوية : 58905
    الاقامة : Earth:((
    السيارة: لا يوجد
    السيارة[2]: لا يوجد
    الحالة : Gabrial غير متواجد حالياً
    شكراً لحضرتك استاذة نورا ،موضوع متميز ،تحياتي.
    الصورة الرمزية Ghamrawy
    رقم العضوية : 4385
    الاقامة : Alexandria
    السيارة: grande punto T-jet
    السيارة[2]: خلاص بخ
    دراجة بخارية: nope
    الحالة : Ghamrawy غير متواجد حالياً
    شكرا على الموضوع المفيد
    اقتباس المشاركة الأصلية كتبت بواسطة khaledelsakaty مشاهدة المشاركة
    مش فاهم !!!
    يعنى ايه ؟؟!
    ايه المطلوب ؟؟
    الصورة الرمزية N.a.j.d
    رقم العضوية : 35093
    الاقامة : JorDan egypt
    السيارة: Corsa 2007 1.4
    السيارة[2]: Astra 2003 2.0
    الحالة : N.a.j.d غير متواجد حالياً
    شكرا ع الموضوع المفيد بس نفسي اعرف حاجه يعني ايه gti
    soon 2011
    [img3]http://img103.herosh.com/2010/03/17/929079106.jpg[/img3]
    لا اله الا الله محمد رسول الله
    رقم العضوية : 70369
    النوع : انثى
    الاقامة : مصر
    Smile -
    شكراً جزيلاً لمروركم الكريم وكلماتكم الرقيقة
    اقتباس المشاركة الأصلية كتبت بواسطة N.a.j.d مشاهدة المشاركة
    GTI = Grand Tourer-Injected
  1. الرموز الانتخابية بعد الثوره حاجه فله اوى
    بواسطة RUN في المنتدى المنتــــــدى الاجتمــاعى
    مشاركات: 12
    آخر مشاركة: 15-10-2011, 02:12 PM
  2. حد يعرف دلالة هذة الرموز على الكاوتش
    بواسطة mfouad10010010 في المنتدى مختــلف أنواع الدراجات النارية
    آخر مشاركة: 13-05-2010, 03:37 PM
  3. هيئة التوحيد القياسى المصرية، و المواصفات الفنية للسيارات و قطع غيارها.
    بواسطة city_ct في المنتدى مقـتـــرحـــــات لحــــل الأزمـــات المــرورية
    آخر مشاركة: 18-03-2009, 12:21 AM
  4. استفسار عن بعض الرموز فى السيارات
    بواسطة fahd_628 في المنتدى المنتــــــدى العـــــــــــام للسيــارات
    مشاركات: 12
    آخر مشاركة: 24-06-2007, 02:18 PM
