يا جماعة طبعا كلنا هنا في مصر بنشتكي من غلو اسعار ال cd بتاع ال ps3 و لان لحد دلوقتي مافيش ولا طريقة غير ال cd فلازم كلنا نتحد مع بعض و نواجه الحكاية دي و كمان نساعد بعض لو في اي مشكلة واجهتنا ياريت كل الناس تتفاعل معانا ان شاء الله
معلش هي بكام في مصر ؟هنا في أمريكا الجم الجديد بيبقي بحوالي 60$ أول مينزل وفيه حاجات قديمة بحوالي 30-40
فيه حد عنده أو بيلعب .. modern warfare.لو عند حد ممكن نعمل فريق ونلعب اونلاين
ودا موضوع عن ازاي تركب هارد ديسك جديد للبلاي ستيشن بتاعك من غير ما توديه لواحد و ياخد منك فلوس كتير ( منقوووول )
It doesn't matter if you have the 20GB, 60GB, or even the new 80GB PlayStation 3--you can always use more storage space. All that available hard-disk space quickly disappears once you start downloading games, demos, and HD videos. Fortunately, Sony has designed the PS3 to allow console owners to perform their own hard-drive upgrades. You can go out and select your own hard drive instead of being forced to buy an official first-party hard-disk accessory. However, giving console owners that freedom means that aspiring upgraders will need to know how to select the right hard-drive upgrade and the proper installation technique.
The first step to replacing the hard disk is going to the store or visiting an online retailer to pick up a new hard disk. The PS3 is compatible with just about any 2.5-inch SATA notebook hard disk. Both 5400- and 7200-RPM drives should work fine. The physical size of the hard disk is important because it has to fit the PS3's 2.5-inch drive tray. As far as storage capacity goes, it doesn't make sense to go through the trouble of upgrading unless you go big: We're talkin' 120GB, 160GB, or even 250GB.
http://image.gamespotcdn.net/gamespo...e_embed001.jpg
Hard-disk manufacturer Seagate supplied us with a 160GB Momentus 5400.3 for our upgrade.
Once you have your upgrade drive, the next step is to back up the data on your current PS3 hard drive to an external storage unit. You can skip this step if you aren't attached to your music, videos, and game saves, but most of us will probably want to save all that information. The PS3 has a built-in software backup utility that can copy the PS3's hard-drive .......s to an external storage device, such as a USB thumb drive or a memory stick. The removable storage device must use the FAT32 file system in order for the PS3 to recognize it. If you have an external hard drive that's formatted in NTFS, you can use the Disk Management utility in Windows to reformat the drive, but you'll need to create partitions on large external hard drives because Windows can only do FAT32 on drives 32GB or smaller.
http://image.gamespotcdn.net/gamespo...e_embed002.jpg
Save your data using the PS3's backup utility.
If your storage device isn't large enough to handle a full system backup, you can selectively copy data over through the various music, photo, and game menus in the XMB. Your PlayStation Network login and system settings will remain safe on the system during the entire process. After you have your data safely backed up, you can move on to the actual hard-drive swap.
You will need a Phillips-head screwdriver to complete this part of the installation process. The PS3 owner's manual also includes step-by-step details on how to replace the hard drive, in case you need more instructions.
e instructions.
http://image.gamespotcdn.net/gamespo...e_embed003.jpg
Turn off and unplug the system. Remove the plastic HD side-panel, and remove the blue screw.
http://image.gamespotcdn.net/gamespo...e_embed004.jpg
Open the ....l latch, move the drive tray to the right, and slide out the drive.
http://image.gamespotcdn.net/gamespo...e_embed005.jpg
Remove the four screws that hold the hard drive to the tray. Use a screwdriver that fits snugly because the screws are extremely tight and easy to strip.
http://image.gamespotcdn.net/gamespo...e_embed006.jpg
Swap in the new drive, and replace the screws.
http://image.gamespotcdn.net/gamespo...e_embed007.jpg
Put the drive tray back into the system and slide it into place. Then replace the blue screw and snap the side panel back onto the system.
http://image.gamespotcdn.net/gamespo...e_embed008.jpg
Turn on the console and let the system format the new drive. Then load up the PS3 backup utility to restore data from your external storage device back onto the PS3 hard drive.
At this point you should have a newly upgraded PS3 and the leftover hard drive. You could try selling the old drive, but small-capacity used drives might not fetch enough money to be worth the hassle of finding a buyer. If you still want to make the drive useful, you can buy an external drive enclosure to make it into a portable storage device.
ودي الطريقة بشرح مختصر بالعربي
1 - عمل نسخ احتياطية لملفاتك عن طريق PS3 Back Up Utility
2 - أغلق الجهاز و إفصله عن الكهرباء .. و قم بفتح الغطاء الموجود على الجانب الأيسر للPS3
ثم قم بفك المسمار الأزرق ..
3- حرك الحديد من مكانه إلى اليمين و قم بإخراج القرص الصلب (ولكن بهدوء .. مو بقوة)
4 - قم بفك المسامرين الأربعة .. (ملاحظة ستحتاج القوة في إخراج المسامير بسبب قوة تثبيتها فأمسك القرص الصلب بشكل جيد)
5 - قم بتركيب المسامير و غيرها من القطع ان وجد في القرص الصلب الجديد..
وقم بتركيبه في الPS3 بنفس الطريقة التي أخرجته منه ..
6 - قم بتركيب الغطاء مرة أخرى طبعا بعد تركيب القرص الصلب الجديد ..
7 - بعد تركيب القرص الصلب في الPS3 كاملا مع المسمار الأزرق وغيره ..
قم بتشغيل الجهاز و قد يطلب منك عمل فورمات للقرص الصلب الجديد وافق على هذا ..
8 - قم باسترجاع معلموات الSystem عن طريق الBackup Utility
بعض الملاحظات المهمه ..
1 - لا يهم نوع الPs3 الذي تملكه (80 جيجا او 60 جيجا او 40 جيجا او 20 جيجا ... ولكن يجب يكون PS3 Fat لأن طريقة تغير القرص الصلب في PS3 slim مختلفه)
2 - حجم القرص الصلب يجب ان يكون 2.5 بوصة .. مثل هاردسك الكمبيوترات المحموله ..
بالتحديد نوع SATA Notebook Hardisk 2.5 inches
3 - يجب ان تكون سرعة الدوران 5400 او 7200 ..
4 - لايهم مساحة الهاردسك .. و يوجد حاليا في الأسواق 160 جيجا و 320 جيجا و 500 جيجا ..
و في يا جماعة فكرة كمان ان كل واحد خلص لعبة و معدش محتاجلها يحطها هنا للتبديل و يبدلها مع لعبة تانية يكون لسة مالعبهاش و الحكاية دي هتنفعنا جدا جدا جدا لان العاب الالغاز بنزهق منها بمجرد اننا نخلصها فممكن نبدل مع بعض الالعاب دي
فكرة هايلة ربنا يوفقكم لما ارجع مصر هشترك معاكم
الاسطوانة هنا فى الرياض من 150 الى 250 ريال
طب طالما انت بقى جامد كده فى ps3 طالب منك خدمة
فى واحد صاحبى جاية من امريكا اليومين اللى جايين وعايزه يجبلى معاه واحد
مش عارف اجيب 120 ولا 250 ولا مش مشكلة حكاية السعة دية
وهل فيه فرق بين slim والعادى .....
ياريت تفدنى فى الموضوع ده؟؟؟؟؟؟؟؟؟؟؟؟؟؟
