حاجة كمان بس بعيد عن موضوع الامبير عشان الناس تستفيد:
ده كلام الكتالوج عن مميزات البطارية الجافة :
The sealed battery has the following advantages over conventional
batteries:
No water need be added for the life of the battery.
It is protected against overcharge. If too much voltage
is applied to the battery, it will not accept as
much current as a conventional battery. In a conventional
battery, the excess voltage will still try to
charge the battery, leading to gassing, which
causes liquid loss.
It is not as liable to self–discharge as a conventional
battery. This is particularly important when a battery
is left standing for long periods of time.
It has more power available in a lighter and a smaller
case.
الترجمة باختصار:
1- مبتحتجش مياه
2- محمية من الشحن الزيادة
3- ليست معرضة لفقد الطاقة زي السائلة
4- قوة اكبر في حجم اقل
5- (من عندي) متهريش قاعدة البطارية
