الكاسيت الجديد بتاعى و عايز رائيكم
ازيكو يا شباب النهاردة ان شاء الله نازل اجيب الكاسيت الجديد دة و كانت عايز رائيكم فية انا هحط الصورة بتاعو هنا و امكانياتو علاشان تقولولى اية رايكم
الصورة
http://www10.0zz0.com/2010/06/28/09/785074588.jpeg
General
Pre Out Output Level (V) 2 Pre Out Impedance (ohms) 220 Maximum Output Power (4Ω, 1kHz) (W) 52 Dimensions (W x H x D) 178 × 50 × 179mm Mounting Dimensions (W x H x D) 182 × 53 × 162mm Weight (kg) Approx. 1.2 kg Accessories RM–X151 Wireless Card Remote (Incl.)
Display Panel
Display Device LCD Display Panel Type Slot-In Panel Finish Colour Gun ....llic Key Illumination Red
Tuner
Preset FM18 / AM12 FM: Tuning Range (MHz) 87.5-107.9, 87.5-108.0 MW: Tuning Range (kHZ) 531-1602, 530-1710 FM: Usable Sensitivity (75Ω) (dBf) 10 FM: Intermediate Frequency (MHz) 150KHz FM: Selectivity (400kHz) (dB) 75 FM: S/N Ratio (Mono) (dB) 70 FM: Channel Separation (dB) 40 FM: Frequency Response (Hz) 20-15k
CD Deck
CD-.... Display / Scroll Yes Multi Session MP3 / WMA / AAC Frequency Response (Hz, dB) 10-20k, +/-1dB S/N Ratio (dB) 120
Ampilifier
S-MOSFET Output Power 52W x 4 Pre Out Front + Rear/Sub switchable Aux-In Frontal Aux-In USB Front EQ3 Stage 2 (3-Band Equalizer / 7 Modes) Bass Treble Low / Mid / High
USB
Repeat Off / Track / Album Shuffle Off / Album / Device Pause Yes Resume Play Yes CODEC (for USB) MP3, WMA, AAC List Browsing (Folders/Files) Yes ZAPPIN™ Yes
