ممكن اعرف ايه اللي بستلمه مع العربيه ؟
Safety System
Standard driver and passenger airbags
Standard ABS/EBD brake system
Two side doors with anti-collision beams
3 Points safety belt with pre-tight unit
Collapsible steering column
Automatic unlock function collision
Automatic lock function at 20km/h
High position brake light
Functional Equipment
Power steering
windows control system
Air conditioner
Tilt adjustable steering wheel
Manual 4 direction adjustable driver & passenger seat
USB connection and AUX input
4 speaker, CD/MP3 compatible sound system
Folding turn for rear seat
Close windows by key with functional remote control unit
Keyless entry
Reverse radar
Electric side view mirrors
Fog light
Alluminum alloy wheels
Max. output power (kw/rpm)
102 - 75/6000
Max. output torque
135/4400
Max. velocity
160
Transmission system
Manual 5 shifts transmission
L*W*H (mm)
4510/1755/1460
Wheelbase (mm)
2580
Tread (Front/Rear) (mm)
1533/1502
Engine
1.5 L DOHC 16V VVT
Wheel
Aluminum alloy wheels 195/65R15
Suspension system
Macpherson
شكرا جزيلا على الرد و لو اني لغيتها من تفكيري بس مش عارف اجيب ايه بدالها
i recommend hyndai getz if hatchback and if you want sedan then hyndai verna full option manual its excellent car
