النتائج 1 إلى 4 من 4
الموضوع: Nitro Book
    الصورة الرمزية Karim_Monir
    رقم العضوية : 32
    الاقامة : جسر السويس-القاهرة
    السيارة: BMW E90
    السيارة[2]: Jeep KK 2009
    الحالة : Karim_Monir غير متواجد حالياً
    افتراضي Nitro Book - Facebook Twitter whatsapp انشر الموضوع فى :
    How to adjust your nitro engine
    When you have to adjust your nitro engine it is important that you have some knowledge of what to do before you get into it. It is at this point of adjusting the engine that most people throw their hands up in the air and give up driving nitro cars. It is a pity, because the nitro engine is really harmless and very simple to deal with, once people have understood its principles beforehand.
    Let me clarify that there is no right or wrong way to adjust a nitro engine as long as the way you do it works for you. Whether you choose to adjust your engine by following the example I have made for you, or by following the advice given to you by the supplier, you still need to understand the principles and factors involved.
    There are 3 screws we works with, when we refer to adjusting:
    - Bottom screw (Low-end) Regulates the conditions for fuel supply in the area within 0-30% of engine speed.
    - Top screw (High-end) Regulates the condition for fuel supply in the area within 30-100% of engine speed.
    - Idle screw, which forms the end stop for the gas throttle-valve and dictates the idle speed.
    When we adjust the bottom and top screw we do it only 1/8 of a turn at a time, no more.
    Is your current adjustment not working and you do not know the suppliers advice for it, you can normally get away with just turning the top and bottom screws 2-3 turns out from the bottom position, but it can vary from engine to engine.
    Before you can adjust your engine you need to always make sure that the working temperature is right. That is, start the engine and warm it up before you start adjusting anything.
    If you adjust more then half a turn out on the bottom screw, it will be necessary to adjust the top screw in
    (and vice versa)
    Adjusting according to weather and temperature
    A perfect combustion in the engine occurs when the relationship between fuel and oxygen molecules are perfectly mixed. The problem is that air does not always have the same number of oxygen molecules in it. It actually depends on the humidity in the air and the temperature.
    You can learn about this and much more in Nitrobook.
    For more visit
    Tips and Information on Tuning, Adjusting Nitro RC Engines – Nitrobook.com
    جروب ورشة نايل موتورز علي الفيس بوك
    صفحة ورشة نايل موتورز على الفيس بوك
    الصورة الرمزية 2faster
    رقم العضوية : 57300
    الاقامة : alex
    السيارة: F16 معدلة لـــF22
    السيارة[2]: bmw 316i coupe modified to m3 بأذن الله
    دراجة بخارية: yamaha R1 or R6 بأذن الله
    الحالة : 2faster غير متواجد حالياً
    شكرا كريم
    بس هي الترجمة حتنزل امته
    اصل كل اللي فهمته ان ده كتاب لتركيب كيت نايترو باحتراف
    [img2]http://www.zercustoms.com/news/images/BMW/2008-HR-BMW-M3-Coupe-3.jpg[/img2]
    soooooooooooooon
    رقم العضوية : 32
    السيارة: BMW E90
    نيييييييييههههههههههههههه هه
    ماهو بالظبط كدة
    وده لينك للي عايز يشترية :-)
    الصورة الرمزية momo10000
    رقم العضوية : 3455
    الاقامة : Haram
    السيارة: Megane II - HatchBack
    السيارة[2]: A-Class 160
    الحالة : momo10000 غير متواجد حالياً
    كريم باشا ..... نورت التعديل كله.....
    الف الف الف مبروك المشروع ويارب تكون عتبته خير عليك.
    عليها السلام
  1. شراء Net book
    بواسطة makram555 في المنتدى المنتــــــدى الاجتمــاعى
    مشاركات: 7
    آخر مشاركة: 01-03-2012, 02:35 AM
  2. نصائح عن My Book 1TB
    بواسطة Sh_sunsea في المنتدى المنتــــــدى الاجتمــاعى
    مشاركات: 37
    آخر مشاركة: 31-07-2011, 01:47 PM
  3. Face Book
    بواسطة yarisawi في المنتدى تـويوتـــا
    آخر مشاركة: 05-08-2010, 02:18 AM
  4. Nitro
    بواسطة Ahmed Samy في المنتدى تعـــديل الســـيارات و الإضافات
    مشاركات: 20
    آخر مشاركة: 23-09-2007, 01:58 AM
