i am suspecting the IAC... it might be acting up and causing this problem
put it on a scanner and see the activity of the IAC during ignition ON and when A/C is turned on during idle
رقم العضوية : 48840
السيارة: Chevorlet Lanos
السيارة[2]: Hyundai Excel
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
رقم العضوية : 48840
thank you very much i will follow your advice and give you my feedback
[fot1][fot1]A life lived in fear is a half-lived life[/fot1][/fot1]
رقم العضوية : 70962
الاقامة : egypt
السيارة: none
السيارة[2]: Lanos Juliet
دراجة بخارية: none
رقم العضوية : 48840
I have just been to Mohamed El Sayed in Dokki ,the guy is really polite and knowledgeable.He put the car on the scanner and started to take some readings.Later he told me that everything is normal but he suspects the coil so we changed it with another one he has .Nothing changes.Finally he said that the car is normal and i have to drive it more smoothly.The hesitation is still on, i really donot know what to do
رقم العضوية : 48840
that was my feedback about my visit,do you have any suggestion?
رقم العضوية : 102
دراجة بخارية: N/A
hesitation in most cases is an electrical problem... we have established that your coil pack is fine... what about your spark plugs and spark plug cables?
use a multimeter to check for the resistance of all four spark plug cables... if the readings are not consistant then you might have a bad set of wires
if your OEM spark plugs are Champions then those are total POS...throw them away and get a set of NGKs
رقم العضوية : 48840
رقم العضوية : 102
دراجة بخارية: N/A
split fire wires are nice... but they are very expensive (some 360LE) and you have to cut them yourself and install the ....l sockets yourself to make a kit that fits your car
it took me two days to get the set ready for use... if money is no object and you got the required skills and time to do it then by all means go ahead and get yourself a set
رقم العضوية : 48840
