http://i27.photobucket.com/albums/c1...6/Slide1-1.jpg
http://i27.photobucket.com/albums/c1...6/Slide2-2.jpg
http://i27.photobucket.com/albums/c1...6/IMG_3459.jpg
http://i27.photobucket.com/albums/c1...6/IMG_3460.jpg
http://i27.photobucket.com/albums/c1...6/IMG_3461.jpg
http://i27.photobucket.com/albums/c1...6/IMG_3462.jpg
http://i27.photobucket.com/albums/c1...6/IMG_3463.jpg
http://i27.photobucket.com/albums/c1...6/IMG_3464.jpg
http://img.photobucket.com/albums/v6...editN16a-1.jpg
photo by unker foo
digital edit by atai
http://img.photobucket.com/albums/v6...0N16/16Vse.jpg
photo by sang
http://img.photobucket.com/albums/v6.../16Vserear.jpg
photo by sang
enjin original sebelum buat transplant.
http://img.photobucket.com/albums/v6.../oriengine.jpg
bay enjin dah kosong.
http://img.photobucket.com/albums/v6...6/emptybay.jpg
bay enjin dah isi ngan SR16VE.....tapi blum siap lagi masa tu.
http://img.photobucket.com/albums/v6...6inprogres.jpg
waktu pembedahan hati.....
http://img.photobucket.com/albums/v6...16/surgery.jpg
dshboard original N16 ngan meter dari N15.
http://img.photobucket.com/albums/v6.../dashboard.jpg
muka yang diberi hidung original balik.
http://img.photobucket.com/albums/v6...20N16/muka.jpg
pandangan mata pandang telus superman....
http://img.photobucket.com/albums/v6...ransbonnet.jpg
enjin bay
http://img.photobucket.com/albums/v6...%20N16/eng.jpg
interior
http://img.photobucket.com/albums/v6...20N16/int1.jpg
center resonator & muffler FGK 2" inlet yang digunakan sekarang
http://img.photobucket.com/albums/v6...a%20N16/01.jpg
hasil dari tuka ekzos.... 0-100km/h, 9sec++ sebelum, 8sec++ selepas.
hasil dari adjustable cam pulley + fuel regulator + uprated injector + customised wiring by KSR = 0-100km/h 7sec ++
ULTRA RACING rear anti-roll bar & Front Lower Arm Bar
http://img.photobucket.com/albums/v6...a%20N16/02.jpg
gambar2 lain akan diupload sikit2........
ENGINE
existing
SR16VE from N15, NEO VVL, 1597 cc 4 inline.
Twin Cam 16 valve.
Balance internal parts to 10K rpm.
Denso Iridium Power Spark plug (IK24).
*latest* K&N M's Air filter.
Custom cold air feed.
5 point 10mm grounding cable.
SR20DET fuel pump set at 3 bar.
NGK Hyper Silicone Power Cable ignition wires.
*latest* 4-2-1 FGK exractor.
2" exhaust pipe till FGK 2" center Resonator + FGK 2" center muffler.
2.5" exhaust pipe to rear muffler.
*latest*2.5" inlet straight flow rear muffler
interchangeable with 2.5" straight pipe end.
AROSPEED Adjustable Fuel Regulator.
Customised Adjustable Cam Pulley.
SR20DET's Fuel Injector (370cc).
*latest*customised wiring by KSR Speed , inlet VVL cam at 5000RPM and exhaust VVL cam at 5500RPM.
future
get rid "2" exhaust pipe till FGK 2" center Resonator + FGK 2" center muffler" and change to 2.5" straight pipe!
TRANSMISSION
existing
SR18DE LSD gear box,
Clutch cable convert to clutch pump.
5 Speed manual transmission.
Short shifter lever.
Exedy Racing clutch cover (pressure plate).
Balance flywheel to 10K rpm.
*latest* Customised Racing Clutch Plate.
*latest* SR16VE's close gear ratio / 4.44 final drive.
future
Lighten flywheel.
WHEELS & TYRE
existing
Godfather 7 spokes monoblock rims,
17”x7 offset 40, 4x114.3 PCD.
2 pc. Aluminium rear wheel spacer (3/4" + 1/4").
tyre:. 215/45/17 HANKOOK VENTUS R-s2.
K-speed alloy valve & nut cover.
Aluminium front wheel cone.
more info about my wheels here: http://nismoclub.6.forumer.com/viewtopic.php?p=45590&highlight=hankook+ventus#455 90
future
Aluminium rear wheel cone.
TOYO R888 semi slick tyre... ahaksss....
HANDLING
existing
ULTRA RACING front upper strut bar.
ULTRA RACING rear upper strut bar.
ULTRA RACING fender bars.
ULTRA RACING lower arm bar.
ULTRA RACING rear anti roll bar.
Front anti roll bar.
future
SUPER PRO P.U bushes.
SUSPENSION
existing
HWL height adjustable coilover with 8F6R spring rate setting.
BRAKES
existing
Front brakes: convert to 4 pot caliper from Nissan Skyline R32, slotted & cross drilled rotors.
Ferodo Zero brake pad.
Rear brakes: from drums brake convert to single pot disc brakes incl. the rear multi-link beam.
Bendix Metal King Plus brake pad.
PRO-RS stainless steel braided brake hoses kit.
future
Upgraded brakes servor & pumps.
BODYWORKS
existing
Modified original front grill.
Modified original front bumper.
Custom made fibre front lips, fibre side skirt, fibre rear skirt, fibre roof spoiler.
Kedaipotong’s custom to fit rear spoiler.
future
Carbon fibre front splitters & carnards.
Customised wide fenders / arches.
Front hood extended.
Ganardo style side mirror.
Bonnet lock.
Vent on hood.
EXTERIOR
existing
PIAA super silicone wiper.
STEBEL horn.
Crystal side signal light (from facelifted model).
PIAA Super LED 5w wedge bulb (2 colour).
PHILIPS crystal vision head bulb.
future
Quadruplets fog light.
Facelift headlamp + smoked or Almera europe headlamp.
INTERIOR
existing
MOMO cobra gear knob.
Carbon fibre look handbrake cover.
Sun-Kool side & rear window tinting
Huper Optik windscreen tinting
Shoulder Pad
future
SSCUS E8 or impreza STI’s semi-bucket seat.
Metal racing pedal.
http://i126.photobucket.com/albums/p...iBeR_/N161.jpg
Side skirt Primera... amar pasanG touch up by TjoL.. http://nismoclub.6.forumer.com/image.../icon_razz.gif
http://i126.photobucket.com/albums/p...iBeR_/N163.jpg
http://i126.photobucket.com/albums/p...iBeR_/N162.jpg
Lips belakanG done by amar http://nismoclub.6.forumer.com/image.../icon_cool.gif
http://i126.photobucket.com/albums/p...iBeR_/N165.jpg
GambO paling Latest http://nismoclub.6.forumer.com/image...s/icon_sad.gif
http://i126.photobucket.com/albums/p...eR_/N165-1.jpg
http://i126.photobucket.com/albums/p...iBeR_/N166.jpg
http://i259.photobucket.com/albums/h...l/DSC00416.jpg
tak mampu pakai spoiler besa
http://i259.photobucket.com/albums/h...l/DSC00415.jpg
grill custom
http://i259.photobucket.com/albums/h...l/DSC00412.jpg
