ده الالكتروني بتاع العربية ال (ecu) خلي بالك ده هو روح العربية وبيتحكم في كل حاجة في أداء العربية وكمان لو باظ مش بيتصلح وسعره غالي
في الغالب بيكون في حوض الموتور .
السيد المحترم دي وحده الاتاكس etacs بتاعه الانذار و السنترلوك و دواره العربيه بمفتاح الريموت و خفقان نور الصالون مع غلق الابواب
وبيكون موجود خلف درج التابلوه الشمال
حضرتك الموضوع ده لتاني مره بتسال عليه والناس بتجاوب اجابه واضحه وصريحه ومحدده لابعد الحدود
دا الكنترول بتاع السنتر والريموت (مش وحده السنتر لا الكنترول بتاع الريموت بتاعها)
اعتقد كده مش محتاج اجابه اوضح
وليه مش موجود في العربيه الفاضيه علشان هيه ما فيهاش تحكم بالريموت
Hyundai Repair: etacs module, dome lamp, door switch
The ETACS doesn't have anything to do with the ABS circuit, so that cannot be the problem with the ABS. Additionally, if you cannot turn on the dome lamp with the switch on the lamp, you've just determined that the problem with that isn't in the ETACS either, since putting the switch in the on position bypasses the ETACS module.
http://www.justanswer.com/questions/...ai-2004-elantr
The ETACS unit, which controls the alarm, is bolted to the dash chassis
and is located immediately behind the climate control cluster, offset a
little to the left. You need to gain access to this unit to code a new
remote. Technically, you are not coding the remote; what you are doing is re-programming the ETACS module to remember and accept the
secret code transmitted by the remote.
Note: The ETACS unit is designed to remember and accept up to two
remote codes. If you wish to add a third remote, there is no other option but to have the dealer program the third remote to utilize the same code from one of your other two remotes (a process called code-saving). The dealer has a Hyundai-specific device for doing this.
دى وحدة الانذار بتاع الفيرنا الكماليات
