بروجكتور سانيو 4500 انسى جديد
جديد بكل مشتملاته السعر 8000 جنيه
sanyo plc xu105
General Aspect Ratio 4:3 (Native) 16:9 Brightness (ANSI Lumens) 4500 ANSI Lumens Contrast Ratio 500:1 Display Type 0.8" PolySilicon LCD x 3 Resolution (Native / Max) XGA (1024 x 768)
UXGA (1600 x 1200) Video Compatibility PAL, NTSC, SECAM, HDTV (480i, 480p, 576i, 576p, 720p, 1080i) Projection Lens F = 1.7 ~ 2.5
f = 19.2 ~ 30.2 Size Dimensions (WxHxD) 13.1in. x 3.1in. x 10.1in.
(33.27cm x 7.87cm x 25.65cm) Weight 7.7 lbs. (3.49 kg) Connectivity Inputs 1 x DVI
1 x Component
1 x RGB D-Sub 15pin
1 x Stereo Mini Jack
1 x RCA Audio
1 x RCA Video Outputs 1 x RGB D-Sub 15pin Audio 1 x 1W Mono Speaker Operation Power Consumption 302W (Normal)
266W (Eco Mode) Audible Noise 34 dB (Normal)
30 dB (Eco Mode) Projection Lens Lamp Type 275W NSHA Lamp Life 2500 hrs (Normal)
3000 hrs (Eco Mode)لاى استفسار على الخاص فقط
