الجهاز ده لو طلبته أون لاين حيوصل لحد بيتك بالشحن ب 142 دولار يعني حوالي 815 جنيه و 10%جمارك و 10%ضريبة يعني يعمل 990 جنيه
ودي صورته في اللينك ده convenient, useful, safe : Buy gps,gsm 850/900/1800/1900 car alarm and tracker - gzhe103k - from ipmart.com ودي مواصفات الجهاز
working based on existing gsm/gprs 850/900/1800/1900mhznetwork and gps satellites
personnel management.
Build-in gps personal locator.
Sos and monitoring functions.
Provide peace of mind for businessman.
Anti-theft of the vehicle/ heavy equipment etc.
Protection of the child / elderly / disabled / pets etc.
Control the trace of anything that is important to you.
High sensitivity, high-end technology and latest gps chipset.
Auto report position.
Built in tf card slot. Support storing data in tf card, the gps data will be stored into the tf card automatically when there
support usb connector and gsm/gps antenna connector.
Built in sim card slot. Support two gsm sim cards, the unit works with the other card automatically when one card has no gsm signal or no phone charge.
Key features
bands ( gsm 850mhz/900mhz/1800mhz/1900mhz )
in dc: 12-24v
out dc: 5v/1a
auto report position.
Support gprs data transmission.
Support sending commands by computer.
Remote sending commands by gprs server and sms.
Get the target\'s latitude and longitude by sms or gprs, and check position on google earth/maps.
Support storing data in tf card, the gps data will be stored into the tf card automatically when there\'s no gprs signal.
Send the last location if the target enters into the blind area.
Add or change username and password and authorized number.
Remote monitoring and sos function, and two-way communication.
Send a geo fence ..... To the user when it breaches the restricted area.
Send a movement ..... To the user when it begins to move.
Send an over speed ..... To the user when it moves exceed of the restricted speed.
Send a low battery ..... To the user if the battery is low.
Send an ..... Of theft to the user automatically if the power be cut off or the vehicle be startup illegally.
Send sms to the unit to cut off the vehicle engine and circuit when someone startup the vehicle illegally in anywhere and anytime.
Applications
manage vehicle rental or outside equipment, etc.
Fleet management.
Protect the child / elderly / disabled / pets etc.
Track criminals secretly.
Package contains :
1 x gps/gsm main box
1 x gps antenna
1 x gsm antenna
1 x manual
1 x tracker
1 x sim card
1 x compact disc
1 x connect wire
product specification
size
80(l)x60(w)x25(h) mm
weight
100g
network
gsm/gprs
band
gsm sensitivity
less than—102dbm
gps chipset
sirf iii chipset
gps sensitivity
-159dbm
gps accuracy
5m
cold/ hot ttff
35/2s
car charger
12-24v input, 5v output
battery power
3.7v dc li-ion battery,1100ma
battery life
about 48hours
operating temperature
-10degrees celsius to 65degrees celsius
storage temperature
-20degrees celsius to 70degrees celsius
relative humidity
5% to 95 %, non-condensing
