BREAK-IN SCHEDULE
CAUTION
During the first 1,200 miles (2,000 km), follow these recommendations to obtain maximum engine performance and ensure the future reliability and economy of your new vehicle. Failure to follow these recommendations may result in shortened engine life and reduced engine
performance.
Avoid driving for long periods at constant speed, either fast or slow, and do not run the engine over 4,000 rpm.
Do not accelerate at full throttle in any gear.
Avoid quick starts.
Avoid hard braking as much as possible.
Do not tow a trailer for the first 500 miles (800 km). Your engine, axle or other parts could be damaged.
INCREASING FUEL ECONOMY
Driving at high speed lowers fuel economy.
Avoid unnecessary stopping and braking.
Maintain a safe distance behind other vehicles.
Use a proper gear range which suits road conditions. On level roads, shift into high gear as soon as possible.
Avoid unnecessary engine idling.
Keep your engine tuned up.
Follow the recommended periodic maintenance schedule.
Keep the tires inflated to the correct pressure. Low tire pressure increases tire wear and lowers fuel economy.
Keep the wheels in correct alignment. Improper alignment increases tire wear and lowers fuel economy.
Air conditioner operation lowers fuel economy. Use the air conditioner only when necessary.
When cruising at highway speeds, it is more economical to use the air conditioner and leave the windows closed to reduce drag.
Use the recommended viscosity engine oil. See "Engine oil and oil filter recommendation" in "Technical and consumer information" later in your car user manual.
