Effective pixels
10.2 million
Image sensor
23.6 x 15.8 mm CCD sensor, total pixels: 10.75 million
Image size (pixels)
3,872 x 2,592 [L], 2,896 x 1,944 [M], 1,936 x 1,296 [S]
ISO sensitivity (Recommended Exposure Index)
ISO 100 - 1,600 in steps of 1 EV. Can also be set to approx. 1 EV (ISO 3200 equivalent) above ISO 1600
Media
SD memory cards, SDHC compliant
Monitor
2.5-in., approx. 230k-dot, low-temperature polysilicon TFT LCD, brightness adjustment and with automatic defeat via Eye Sensor
Exposure metering
3D Color Matrix Metering II, Center-Weighted and Spot Metering
Exposure modes
Digital Vari-program (Auto, Auto [flash off], Portrait, Landscape, Child, Sports, Close up, Night portrait), Programmed auto (P) with flexible program, Shutter-priority auto (S), Aperture-priority auto (A), Manual (M)
Interface
Hi-Speed USB, Data transfer protocol: MTP, PTP
Power sources
One Rechargeable Li-ion Battery EN-EL9, AC Adapter EH-5a (optional, used with optional Power Connector EP-5)
Dimensions (W x H x D)
Approx. 126 x 94 x 64 mm (5.0 x 3.7 x 2.5 in.)
Weight
Approx. 495 g (1 lb. 1 oz.) without battery, memory card or body cap
